Kielly
2024 Tacoma Sport+ 6M
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop asdasdasdasdasdasdasdasdasdasd
I'm going to start this by saying this was a trial and another one of my ADHD impulses. The wiring isn't 100% where I want it, a lot of my tools and connectors were left up to the camper.
I came across a post on Facebook and thought it looked amazing. I lost the picture almost immediately but found another guy who done the same as seen below
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop FB_IMG_1726521837455
I searched Amazon endlessly to find marker lights that would be small enough to fit in between the grille sections inside the hood scoop, and also easy enough to install. This is what I found
LINK: Amazon Canada (sorry US friends)
I ordered the 11mm at first, and it was way too large so I ordered the 6mm, and when they arrived today they looked insanely small and had me worried, but they worked. This isn't the final product for me. I'm not happy with how the lights are more friction fitted than they actually are backscrewed, I'm also not happy with the way the grille is flexing (because they're friction fitted), although it's not really noticeable unless you get eye to eye.
I was worried the round markers may look stupid but I was wrong (at least in my opinion). If I can find small enough rectangle lights I may consider switching, but ultimately I want to do rectangle markers in the grille it's self. I'm eventually going to cut a plastic backplate and backscrew the lights onto that and then place the backplate behind the grille of the hood scoop, that way it's less noticeable and more solid, won't have to worry about any lights shifting.
I didn't hook it up to the DRL like I planned, I took the easy way out and hooked it up to AUX3 up front by the right headlight, as my ditch lights were already wired into AUX2, so the wiring was already there and ready to go, I didn't feel all that great about T-tapping into my DRL wire, plus now I can independently turn them on and off, when I do get around to getting some grille markers, I'm also going to wire them into AUX3.
Taking off the hood scoop was easy. 3 bolts under the hood, and then one final bolt behind them all hidden. The rest are just plastic clips. BOY was it dirty under the hood scoop.
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_181230
Once the hood scoop was off there's 4 screws you unscrew to separate the two pieces, this gives you all the room needed to install the lights. This is where I ran into a problem
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_181236
I overlooked how the wire was going to run down through the hood. Currently, I don't feel good about drilling a hole into my hood, where the hood scoop would hide it, but eventually I think I will have to. Instead, I slipped out the screw that hid on me as seen in the picture and routed the wiring through that, and then in-between the two panels of the hood. The wires exit near the hood hinge and from there I have them tucked away running up to my passenger light.
So if anyone can take anything out of this just know to do this:
  • You need to either go through an existing hole in the hood, which means one less bolt. Or, drill your own hole.
  • You probably need to have some sort of backplate for your lights, as sticking them through the grilles doesn't look the best. There's probably some lighting out there small enough that'll mount nicely without it though, I don't know.
  • If you do plan on sticking them though the grilles you need something 6MM or smaller, which means less lumens usually.
  • If I am to get new lights, I may consider getting something smoked, less noticeable when off.
That said, here's some pictures. It was getting dark so it was hard to capture what they look like off but I tried my best. It's almost dark out there now, once it is I'll get some photos and post them here.
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190514
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190517
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190521
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190617
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190651
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190655
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190716
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_192450
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_190453
Here's some night pictures. It looks much, much better with the eye than it does on my scratched up crappy camera lol. Tried my best to capture what I was seeing but couldn't. Too much glare happening on the camera
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_224322
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_224330
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_224341
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_203103
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_202910
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_203127
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_202949
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240916_202925
Tacomasaurus Rex
2024 Toyota Tacoma TRD Sport
I need these!! That looks amazing. Unfortunately I am in the US and am having a hard time finding something similar
Kielly
Kielly
Just a little update to anyone wanting to do this themselves, I scrapped it all again today with the intent of putting some blocking behind the grille to hide the lights better.
In typical me fashion, that idea was scrapped almost immediately ($70 down the drain) and I put a drill to the hood scoop. Behind the grille part, there's about 3 inches of opening, and then a backplate already. Hard to explain and my phone was dead couldn't take pictures.
I drilled 6mm holes into that backplate and installed the lights there. So far I like it more, although it's not as pronounced in the day. I have yet to see it at night. See below for pictures
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192549
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192506
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192528
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192540
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192531
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192513
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop 20240917_192455
Jer8274
Jeremy
2024 Tacoma TRD Sport 4x4
Thanks. I think the blue would look great on my metallic blue crush TRD Sport 4x4; however, here in Texas I'm willing to bet that blue lights in my hood will land me red and blue lights flashing in my rear view mirror. Probably go with another color. Lol.
Kielly
Kielly
This is awesome. I am inspired to do this immediately lol
You won't regret it! Cheap and *easy.
I'm just waiting for someone to make pop in lights for the grille, in my opinion it looks great, but half complete. I think grille markers will complete the look.
Tire fryer
So Cal
1999 Ford F250 7.3 4x4
Perfect place to install KITT front scanner light and feel like the Knight Rider
Kielly
Kielly
It was suggested and I thought about it, but I'd most definitely leave it on and the cops would have a field day with me I feel lol
Viper_00
Walter
VA
This has been so inspiring so thanks for the write up.
Has anyone found a slim line light bar to fit in the sport hood scoop cavity? Ideally that’s the route I’d like to go.
Kielly
Kielly
You bet! I agree a light bar would be pretty rad in there, there's surprisingly enough room in there so it should be hard to come across one.
If I had my time back, I wish I took measurements of the inside.
Viper_00
Walter
VA
I took some measurements and the actual width is 11 1/8 so probably a 10” bar max. 3/4” height and 1” depth max unless we cut into the plastic tray. It’s a tight fit. In my search I haven’t come across anything yet. I’m sure some companies will develop something soon.
Viper_00
Walter
VA
I was inspired by this mod. So I found a 7” led light bar from Nilight and it actually fits perfectly. I hooked it up to the AUX 1 in the engine bay. Super easy.
2024 Tacoma DIY: Amber Marker Lights in Hood Scoop IMG_5641
