CATOY
Here are the measurements for the storage compartment (if equipped) , keep in mind that the top and bottom depths are not the same. The cover measurements also shouldn't be used as there's a ridge it sits on unless you plan on cutting the box out.
Let me know if you require more precise measurements and I can great a jig to fit in there.
Here are some more pictures with the box removed. The last couple are measurements of the edges of the unit.
