- Joined
- Feb 11, 2024
- Threads
- 2
- Messages
- 9
- Reaction score
- 33
- Location
- Long Beach, California
- Vehicle(s)
- Toyota CH-r
Nice set up!
Is your suspension the same as the SR? Will that tire setup fit the SR?
The TRD OR does not have the same suspension as the SR. I believe it sits a little higher.Is your suspension the same as the SR? Will that tire setup fit the SR?
Hi Dubz. Great looking truck. So are you saying that a 285/70R17 is rubbing/won't fit at stock ride height? I think the stock offset is +45 as well if I'm not mistaken. I was thing of going with Falken WPs in a 285/70R17 on some Method wheels with a +35 offset. I've heard conflicting thoughts as to if they will fit at stock ride height with no trimming. What are your thoughts/experience? Also, what did you do for TPMS sensors? Thanks.The Tacoma has to be lifted in order for 285's to fit.
I like the way that bed looks over the shorter bed.
I agree. It does looks better over the shorter bed.I like the way that bed looks over the shorter bed.
the OR is a little taller up front and obviously has a different rear suspension from the SR. SR/SR5 tread width is also 1cm narrower, the base wheel off-set is probably 5mm greater.Is your suspension the same as the SR? Will that tire setup fit the SR?
Something bothers me about that being taken at the psychology department...
