Disable Wireless Charger
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
My phone doesn't support wireless charging, but that spot is perfect for holding it while it is charging on a cord. So, I set out to disable the charger. Took pictures in case it will help someone else.
Another post somewhere said the fuse was under the glovebox. Manual shows where and how to open.
2024 Tacoma Disable Wireless Charger 1-IMG_20240729_094654354
Just need to push the clips forward and pry gently. The flex it a little to get it out.
2024 Tacoma Disable Wireless Charger 2-IMG_20240729_093736732
Box is on the right
2024 Tacoma Disable Wireless Charger 3-IMG_20240729_094438965
4th fuse position down on the right.
2024 Tacoma Disable Wireless Charger 4-IMG_20240729_094037563
2024 Tacoma Disable Wireless Charger 5-IMG_20240729_093745493
2024 Tacoma Disable Wireless Charger 6-IMG_20240729_094100840_HDR
2024 Tacoma Disable Wireless Charger 7-IMG_20240729_094218679
Trick to getting the panel back on is getting the back pins into the square holes.
2024 Tacoma Disable Wireless Charger 8-IMG_20240729_094504443
2024 Tacoma Disable Wireless Charger 9-IMG_20240729_094551641
NS, Canada
I have a wireless charge capable phone but hate the oem wireless charger so this is awesome, plan on using this as a guide if the truck I ordered ever becomes real
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Bumping this up. I myself I do not like wireless charging but want to keep my phone there.
thanks!
-Josh
