The gas only 2.4 models will likely have the best payload capacity and tow capacity. Towing capacity is more complicated than just torque numbers. Vehicle weight also affects towing figures and the added weight of the hybrid system on TRD Pro / Trailhunter, plus all their extra equipment like rock rails, skid plates, swap-bar disconnect, etc. lowers their overall towing capacity.Will the Hybrid Tacoma models like the TRD Pro and Trailhunter with their 465 lb-ft iForce max engines naturally tow more than the gas only models with significantly less torque?
The hybrids will be able to tow up to 6000lbs and gas up to 6500Will the Hybrid Tacoma models like the TRD Pro and Trailhunter with their 465 lb-ft iForce max engines naturally tow more than the gas only models with significantly less torque?
This article is over 3 months old
