I can keep track of how the last fillup is doing using this methoc. But I use the Fuelly app to keep track of all my fillups and maintenance.So, assuming this is by Tank?
My truck does not display the previous best. It always reads 0.00. I've commented on this before but still havent found the reason.Took me a little time to figure out how to do it.
After tank fill up ….
1. Vehicle info on your display
2. Trip information
3. History
4. Tap tap Update
Your previous Average MPG will move to the left and your new Average MPG will start to the right. This will also reset your Total Average setting in your instrument cluster. The pictures are a little misleading because the MPG numbers are different, but that because I was sitting in the truck in the driveway, with it running and the MPG was changing, both the places will show the same MPG. Do this at each fillup. If you tap Clear
All - All your data will be cleared and it will start over. I don’t see a need to ever do that.
Total Average is total since you tapped Update.
