Max Amps for 12 Volt Plugs? Looking at air compressors.
Tacocat
MA
Outback
Looking to get a portable air compressor for my 2024 Limited (non-hybrid) and didn't know what the Amps were for the 12 volt plugs in the cab and in the bed. I see the 7.5 amp fuse near the bed 12 volt plug, but didn't know if that was for the plus.
I'm looking at a 10 amp or 15 amp portable compressors. Are those too much for the bed plug? How about for the cab? Thanks!
TrustButVerify
Several
A compressor that runs off a cigarette plug emits so little air its basically a homeopathic tire inflator. The typical limit is 10 amps for the cab. With the truck running. If you want to fill a truck tire before the heat death of the universe, it will need to be a hardwire or battery clip compressor and they draw about 25amps minimum.
What are the fuses in the fuse box under the hood showing?
Tacocat
MA
Outback
I'll check under the hood tomorrow. Was looking at one of these (https://no.co/products/air/air-compressors). Guess the Air15 would draw too much and based on your comment the Air10 wouldn't be worth it. Thoughts on the Air20 (connects directly to the battery).
TrustButVerify
Several
I have no familiarity with the Nocos. I like Viair, for no reason. 300p
https://viaircorp.com/products/300p-portable
There's an additional 10% off coupon I found. Bing adds it automatically if you use the shopping spybot.
gofastdan
Not familiar with Noco either, I have the basic Thor's Lightning compressor and love it. If you look around there are three or four companies selling effectively the same unit, just rebranded. They do work well though. I can inflate all four tires from 20 to 32 lbs in 2 1/2 minutes, which is crazy.
That said, it's much bigger and heavier than what you're looking at so you have to decide what your priorities are. Regardless, I agree w/TrustButVerify that if you're wanting anything other than an emergency inflator for an air mattress you're going to be looking at something that connects directly to the battery (and you'll have the engine running when you're using it...).
