Stage Series Bed Light Kit | Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
2021 Toyota Tacoma
2024 Tacoma Stage Series Bed Light Kit | Diode Dynamics qsuLtv3
Add significantly more light output to your truck bed at night with our Stage Series LED Bed Light Kit for the Toyota Tacoma!
2024 Tacoma Stage Series Bed Light Kit | Diode Dynamics i2goPcw
This kit allows you to mount four Stage Series LED Rock Lights to the bed rail on your truck bed, giving you a huge increase in light output. The included wiring harness plugs into your factory wiring, allowing the rock lights to illuminate when you open the tailgate, just like the factory bed lights.
2024 Tacoma Stage Series Bed Light Kit | Diode Dynamics xLvWuOC
Unmatched Light Output. The factory bed lights just don't provide enough light output when loading or unloading your truck bed at night. By pairing optically engineered lenses with high-powered LEDs, the Stage Series Rock Lights included in this kit provide a significant increase in output that's several times brighter than stock bed lights alone. Plus, they automatically come on when you open the tailgate!
Optically-Engineered, Interchangeable Lenses. When adding more light output to your truck bed, most options on the market are built without optics in mind. They use a simple clear cover to protect from the elements. In true Diode Dynamics style, we’ve incorporated optical features to get the best performance possible. Four individual optics are molded into the outer lens, which provides excellent spread and even, consistent coverage from each light. The lens itself is a thick automotive-grade polycarbonate, made to take a beating. And the best part? The lenses are interchangeable, and can be swapped out easily for a quick color change, with either clear or diffused options.
2024 Tacoma Stage Series Bed Light Kit | Diode Dynamics lCPIm2F
Simple Installation. The included wiring harness plugs directly into the factory bed light wiring for simple installation. The Stage Series LED Rock Lights will then mount onto the included T-Slot Nut to mount it along the factory bed rail.
In the Box:
  • Four (4) Stage Series Rock Lights
  • One (1) Stage Series Bed Light Wiring Kit
  • Four (4) T-Slot Nuts
  • Mounting Hardware
  • Installation guide
Quantity: Four (4)
Warranty: 8 year warranty
Return Policy: 30-day Return with no restocking fee
100% Satisfaction Guarantee
Proven Reliability. We know your bed lights will be put to the test, so you can rest assured that they have been designed for superior durability. They are IP68 waterproof rated and feature a cast aluminum housing and pin-fin heatsink, for effective thermal dissipation. The lens is designed with thick automotive-grade polycarbonate, and a UV coating. Backed by a limited 8-year warranty, they have been tested in-house from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. Rest assured, the Stage Series Bed Lights will handle whatever you throw at them.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly assemble and engineer our own products in the United States, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
2024 Tacoma Stage Series Bed Light Kit | Diode Dynamics 99dGsGx
Click HERE to shop the Stage Series Bed Light Kit for the 2024 Toyota Tacoma!
Questions/Concerns:
Hours:
Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
