Trailhunter: No power at the bed 12v or USB-C ports
rchrds
TN, USA
2024 Trailhunter
So I have been setting up some lights in the topper, and went to plug things in, and found that I don't have any power in the 12v connector or the USB-C ports in the bed on the compressor panel. The Compressor works fine. I have tried both with 120v inverter on, and off, as there has been some rumor these ports might be tied to the 120V inverter. The connector is plugged in behind the wheel well panel. Any ideas? There doesn't seem to be anything in the manual, and I haven't seen any options in the vehicle setup menus.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
Is there a fuse holder back there? I don't have a "compressor panel", but my bed 12V & USB C panel has a fuse holder in it.
j.
Willm8
William
Takoma Park Maryland
2024 Toyota Takoma Trailhunter, Black 6ft bed.
Did you try it at the same time as the compressor power switch was on?. That's how it works in my TH. I was looking for a 12v source for something. I was going to pursue using the trailer connector plugs, but those are outside which is what I want. But also I believe 2 of the aux switch circuits terminate under the bed. You should have 3 pigtails that came with the truck. And here is a door on the right side that has drain holes behind it that wiring could be routed through
Sandytntn
Tennessee
Tacoma TRD Sport Premium 2024
The fuse was blown when i bought my truck. Have not used since replacing but i think was only a 15 amp so may need bigger one.
