TRD PRO Operator Questions
fourharts56
Ray
2024 Toyota Tacoma TRD PRO
Greetings everyone!
I have 2 questions that are either operator error or design things I have to get use to.
First of all I have read all the manuals and searched all over the internet but still have no clear answer.
1. This is a HUD question. In order to get my HUD to display the tachometer every time I start the truck I have to press the cruise control mode switch twice to switch it from dynamic cruise control mode to normal cruise control mode even though I am not using the cruise control. It will not stay in normal mode after shutdown and restart. Does this sound normal?
2. I use the auto climate control a lot and I have noticed every so often I will look down and see the AUTO light is out on the climate system like it just turns off. I read through the manual and it says something about in ECO mode it will control the system for efficiency but this happens in any mode. Anyone else have the AUTO climate control just randomly shutting off?
fightforfood247
Matt
Syracuse ny
2024 Tacoma trd off road
For the auto climate one noticed this as well. Seems from my end. The truck has reached the set temp and turns off. Then with time it’ll turn on again when needing to kick on ac or heat.
timetoeatpotatoes
A
CA
2024 Trailhunter
Did you turn on front defrost or make any presses for climate? Pretty much anything you do will trigger auto to disable.
I know eco will run the climate system less but I dont think it actually takes it off auto.
fourharts56
fourharts56
Ray
Thanks for the replies.
no I did not push any of the buttons, it was operating in auto and when I looked down later it was off. I didn’t wait long enough to see if it would come back on its own, so that is the next test, thanks.
