Tired of struggling to climb into your lifted Tacoma? Our heavy-duty running boards deliver 600 lbs of support while giving your truck that clean, aggressive look.
WHY TRUMGETA RUNNING BOARDS?
PERFECT FIT
Made exclusively for 2024-2025 Tacoma Double Cabs
Not compatible with:
• Xtra Cab models
• 2005-2023 Tacomas
BULLETPROOF CONSTRUCTION
• Aerospace-grade aluminum – Lighter than steel, stronger than the competition
• Black powder-coated – Resists rust, scratches, and UV damage
• Non-slip pads – Textured plastic for grip in all conditions
600 LB CAPACITY
• 4 reinforced brackets/side (most brands use 3)
• One-piece die-cast bar – No weak welded joints
SMART PROTECTION
• Shields rocker panels from debris
• Square cap design – Cleans up the wheel well look
30-MINUTE INSTALL
• True bolt-on – No drilling, no welding
• Complete kit includes: (2) Running boards, (8) Heavy-duty brackets and All hardware + instructions
︎TACOMA OWNER APPROVED
" These made the truck look way better and the ease of going in & out of the truck is so much easier compared to the OEM steps. Install was a breeze as well! " – @kevztaco
Ready to step up your ride? Get yours today!
Have questions? We’re here to help!
PERFECT FIT
• Xtra Cab models
• 2005-2023 Tacomas
600 LB CAPACITY
SMART PROTECTION
30-MINUTE INSTALL
