Installed the Beat-Sonic amp today. Super easy on 4th gen. Noticeable difference in volume level needed and bass.
Super easy. Trim behind radio just pops off.Mine came in yesterday. Looking forward to having a few minutes to install it soon. Hopefully I donāt mess up my dash or anything. I ordered a set of different trim removal tools and non-marring pry bars just for it. Hopefully it turns out well. Anything that wasnāt straight forward about the install, or was everything pretty straight forward?
Thanks brother. yes sir I watched their video. I believe he said in the video that there is only one place all the connectors could plug in, with the exception of one plug that also had another that would fit, but would not work if the wrong one was plugged in. Did you need to unhook your battery or anything?Super easy. Trim behind radio just pops off.
Just unplug the two wires and reinstall. I believe it was the black and gray connections.
Just watch their YouTube video on the 2024 install.
Itās always recommended but I personally didnāt. Have done many stereo installs and still donāt.Thanks brother. yes sir I watched their video. I believe he said in the video that there is only one place all the connectors could plug in, with the exception of one plug that also had another that would fit, but would not work if the wrong one was plugged in. Did you need to unhook your battery or anything?
Iāve done a few myself, but its been 20 years and on vehicles not nearly as expensive if something is brokenItās always recommended but I personally didnāt. Have done many stereo installs and still donāt.
All speakers. Gives everything a bumpIs this Amp just for the sub or all speakers?
Did you do the correct wires and ground the unit like in the video. Check all connections.Well fuck me lol
yes sir, checked and double checked before I turned the power on. I didnāt have the engine lights before I wasnāt getting power to the head unit. I checked the fuses and then I got those .initially I just didnāt get power to the radio.Did you do the correct wires and ground the unit like in the video. Check all connections.
Really weird.
https://www.beatsonicusa.com/ena-2t3.htmlIs there a specific model number for the BS amp that works with this truck?
I installed mine the other day. Itās not insanely loud like a big amp, but rather it gives you probably an addition 10,15, maybe 20 volume levels. What used to be 45 I only need to go to 25-30. Base is about the same. I think it really just made it sound like how it should have came from the factory. Down the road I may add a beefier sub, and dedicated smaller amp, but weāll see.Installed the Beat-Sonic amp today. Super easy on 4th gen. Noticeable difference in volume level needed and bass.
