- First Name
- Josh
- Joined
- Feb 11, 2024
- Threads
- 8
- Messages
- 258
- Reaction score
- 249
- Location
- Halifax, NS
- Vehicle(s)
- 2025 TRD Pro
Your recovery points have recovery points
Nice truck brother congrats and welcome.
About your axle dump exhaust, did you notice any lag or sluggishness in the engine? I have the same engine (non hybrid) and want this too. Just making sure deleting that last resonator thing doesn’t affect the turbo or anything. Thanks!!
I liked the look. When I first went after it I thought it might look over done but it adds a nice noticeable touch to the rear of the truck. BTW loving that TRD Pro that your driving.Your recovery points have recovery points
You mean GO DAWGS!!!!! lolI hope you got a huge discount with all that UGA stuff the dealer put in there. I’ll send you some UK gear to cover it up. Go Cats.
Ok cool. Thanks for replying broNo lag or sluggishness what so ever. Only thing that changed is the tone got slightly louder but it's barely noticeable.
Thank you again for the info. I installed the brackets on the rear today with 1/2 inch grade 8 bolts. They fit perfectly and it was an easy install. Amazing that you figured out this work-around to attach these brackets to the Gen 4. I can’t believe the manufacturer is not marketing them to Gen 4 owners. I jokingly thought about buying them up for $30 and rebranding to Gen 4 owners for $60 which would still be less than half of other brackets LOL. Thanks again!!!No prob. I bought these
https://a.co/d/6F9eD2G
If you run your hand along the bottom of the frame just before where the plastic part of the bumper curves down you will feel a hole. The brackets I bought came with d rings but they fit around the frame perfectly. I think any of the front d ring brackets for the 3rd Gen will work tho. Can't remeber what size bolts/nuts I used but I know they were grade 8. You just need a ratcheting wrench long enough to fit and run down the inside of the frame rail to tighten them down. I think mine where 9/16 or 1/2. It's a good alternative to 200-300 dollars for the recovery points.
