285/70/17 tires with or without lift?
Powhunter
Alberta
Here’s mine, 17x8 +20 wheel with 285/70R17 Toyo R/T which says 33.0” diameter on the spec sheet. Likely the same as your Falkens. Stock suspension. Running about 32-35psi and been happy with the ride.
Small lift will be going on when those wheels go back on in the spring.
2024 Tacoma 285/70/17 tires with or without lift? IMG_8922
2024 Tacoma 285/70/17 tires with or without lift? image6
2024 Tacoma 285/70/17 tires with or without lift? IMG_9613
DesertFast
DFW Texas
2024 Tacoma TRD OFF Road
Did you get in on the Icon sale they had them wheels a month or so ago? I picked up the same ones as yours for like 176.00ea.
yes, I did. I originally had the pros but my local tire place refused to put them on so I settled for those because they were cheap and nice enough so that the build would look good.
DesertFast
DFW Texas
Those are great photos thank you. They really show that I’m not too far off with how mine are set up. I really appreciate it. I felt like there was something wrong with my Tacoma because everyone else sounded like they had 6 inches on either side.
Powhunter
Alberta
Yeah there’s not an abundance of space, but I’ve flexed it out pretty good off-road and have never had a rub.
Devildog81
minnesota
2024 tacoma trd offroad
I was looking at them bronze bead locks they had marked down to like 120.00ea, but they were a 0 offset. Wasn’t quite sure if I wanted that much tire/wheel poke, but after seeing some builds with 0 offsets I kinda wish I would have got them. 0 offset with some wider fender flairs look pretty nice.
