Popping sound beneath rear of truck bed?
Tacorey
Corey
Atlanta, GA
2025 Tacoma TRD Offroad; 2007 Infiniti M35
I just got my truck and was walking around in the bed to check everything out. I noticed a popping noise coming from the truck bed, but wasn’t sure what it was. I checked the spare tire, it looks tight. I also looked beneath the truck to see if anything looks out of the ordinary, but I didn’t see anything other than a hole that “might” be missing a bolt but not sure.
I decided to walk around on it some more, and it seems like the only place it happens is near the tail gate in the center. It sounds to me like the bed is bowed up, me standing on it compresses it down, and the pop sound I'm hearing is from it unsticking from whatever is below after the weight is released. Is this normal? It’s similar to a hardwood or laminate floor where there’s a tight area that bows up a bit, and when you step on it, it makes a pop/unsticking noise after you remove your foot.
SDchrisC
CA
Tacoma TRD OR
I Thought I was the only one!! I Have this same exact issue and cant pinpoint where it coming from.. if you find out can you post it
Tacorey
Corey
Atlanta, GA
Will do. Might try to take it to the dealer this weekend. Do you have the spray in liner?
Tacorey
Corey
Atlanta, GA
No just the regular composite bed
Okay, mine came with the spray in, so doesn't seem like it's related to that. My guess is a bed alignment/bed binding issue. I will update when I get a chance to get it checked out.
