Jeeper Defector
Charlotte
Currently Jeep JT Gladiator
Update: confirmed - you can remove the air dam by simply unbolting 9 bolts
The front air dam is pretty big on every trim below Trailhunter. Think it'll be easy to remove the air dam? The downside I guess would be how big of a hit this would be on aerodynamics and MPG fuel efficiency numbers... 🤔
Here it is on the TRD Sport
2024 Tacoma Air dam is easy to remove. Removing affects MPG fuel efficiency / aerodynamics how much? remove air dam 2024 tacoma removing removal removin
And here it is removed:
JLD94
JD
Tx
Most seem to mention that it is easily removed by 9 bolts. My question is like yours how much real world difference will it make
BigDan
MD
Yep air dam removable by just unfastening 9 bolts. Here it is with air dam removed
Rocky
Rocky
Georgia
2024 Tacoma (hopefully)
This is a great question. Some Tacoma owners report very little change in fuel efficiency on previous versions, but we haven't had a Tacoma with the powertrains offered in the 2024 model until now. This article from The Drive offers an option. You could remove it when heading out on the trails and put it back on after. This might give you the best solution.
https://www.thedrive.com/news/why-t...y, the air dam redirects,the field if need be.
JimS
MD
21 ID.4, 15 Sienna
Was wondering same. It is comically huge - like a mini snow plow. Even if not off road I could see it getting caught on curbs when parking.
ToyTrucker
Jim
TX
Another confirmation that it just takes unbolting 9 bolts to remove the air dam 👍
TacoFly
PC
North of the Columbia River
14 Crosstrek, 21 Bronco FE, 07 TRD Taco (Sold)
That air dam should be called "The EPA spec sheet enhancement device"! 😆
Thats got to worth a good 2-3 mpg enhancement on the final EPA official milage per gallon #'s. In fact I'd bet without it the new milage ratings won't be good for more than 1 to 3 MPG from the current truck(depending on trim).🤷‍♂️ Will be interesting to see.
MPGunther
Mark
Phoenix
2021 Toyota Tacoma Sport
The difference in removing the dam on my 3rd Gen was only a negligible difference in milage.
LuckyMonkey
TX
02 Ford Lightning
From what I've read on other vehicles they help at highway speeds but detract at city speeds.
Maybe gain 1 mpg city and lose 2+ at highway speeds.
Cavemold
Cavemold
CA
Ford Maverick 2022 Eco 2.0
looks much better i dont think mpg differnce will be much but i am curious to see real testing done
