ARB Soft Shackle - Save a $
JED
Southern Tier NY
2015 Tacoma TRD Sport
Three days after I installed the ARB left side recovery mount the soft shackle showed up.
Playing around with it it dawned on me that it can be used around the trailer hitch frame. Kind of eliminating the need for the mount.
An opportunity to save a couple hundred bucks! Story of my life.
2024 Tacoma ARB Soft Shackle - Save a $ IMG_6915
2024 Tacoma ARB Soft Shackle - Save a $ IMG_6916
NS, Canada
So when you put tension on it it’ll take out the bumper cover eh?
tkrum015
Ted
Olympia
24 Tacoma TRD Off-Road
Use the new pull point does not have the sharp edges and is made for pulling
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
I think he's suggesting that you can forgo buying the recovery points and just get some soft shackles. The hitch frame is nicely rounded near the ends. However, there are some flat plates welded to it near there that are rather sharp and could cut the shackles if they slide much.
I'm planning to get a recover hitch receiver myself. I'm also planning to avoid any serious "stucks" like the plague.
Not sure what I'll do about the front. I think the weak point is going the be the frame so buying a thick chunk of metal and bolting it in place of the stock tow loops doesn't make much sense to me at this point.
Reactions: JED
