How much rake does your stock suspension Tacoma have?
Powhunter
Alberta
I’m trying to determine if different models might be higher in the front. Post what model you have and what your rake is (difference in height between front fender to ground and rear fender to ground)
I have a TRD OR on stock suspension and my rake is 2.0 inches.
Richm
Richard
VT
2024 TRD OffRoad, stock suspension
Going by wheel well opening, i have 37" in the rear and 35 1/2" in front
If you measure the lip on the bottom of the rocker panel, i have 16 1/2" rear measurement and 15 15/16" in the front.
So if i did a 1 1/2" front lift, it would even out the wheel well openings but in my opinion it makes it look nose high if you go by body lines and bottom of rockers/cab
