Tualatin
Got a little lift installed and slapped on some new shoes today.
Readylift 2.5" SST Kit: https://www.readylift.com/2-5-sst-lift-kit-toyota-tacoma-2024.html
BFGoodrich All-Terrain T/A KO3: https://www.bfgoodrichtires.com/auto/tires/all-terrain-t-a-ko3
I wanted to add a little height, even out the stance and a little bit bigger tire. Overall I'm happy but with the Smartcap Evo Adventure and the rooftop tent there's a little bit of sag from the factory rear coils and it's a little nose-up.
I ordered up some heavier load rear coils from Dobinson's that we're putting in when they arrive, that should help with the rear end and should be my sweet spot.
2024 Tacoma Installed Readylift 2.5" SST Lift and BF Goodrich K03 285/70R17 on stock TRD Offroad Wheels IMG_7726
4thgenmedic
Matthew
Tennessee
2024 Sr5
add the timbren bumpstops in rear and the peak design 1 inch coil lift... problem solved!
RandomGuyInPNW
Tualatin
I got the Timbren TORSEQ3 bumpstops but haven't put them in yet. The Readylift kit has a 1" coil lift in the rear.
I didn't think the Timbren added any physical height, just a softer bump and support when you have a load in the bed, no effect on your daily drive setup.
Ericscott21
Eric
2024 Tacoma TRD ORP
This looks awesome, I was considering this exact tire/lift setup for mine. Did you get the standard load KO2’s? Any comment on MPG loss?
RandomGuyInPNW
Tualatin
Thanks!
I ended up with the 10 ply Light truck KO3's, the standard wasn't in stock in town.
Too early to really tell mpg but it doesn't seem to be anything noticeably different.
Ericscott21
Eric
2024 Tacoma TRD ORP
Thanks!
Thanks for the quick reply! Really been wanting to level and put KO2’s on but have already put 13k miles on since I bought it in April so MPG is a concern. Thanks!!
elturco
Cesar
San Diego
I have been debating on weather to get the C59-819V 440-660lb Load or C59-821V 800-1200lb. I mean, if I count my passenger weight of 450 pounds and 550 of camper and things... I would be at 1000 lbs.. when camping... or 600lbs as daily driver.... Will the C59-819V sag much? I would love to hear your feedback once you get them installed..
