Best product for buffing scratches out of gauge cluster area?
I bought some cheap panel removal tools on Amazon, which makes that stuff easier and less damaging. Everything I have removed so far has been simple to do, and most panels are just push connectors that make remove/reinstall easy.
Jeff11
Jeff
Pittsburgh
When you say push connectors, what do you mean?
A lot of the panels have connectors with pins which push into holes where they mount. The parts just pop loose when they are pried off and push back into place when you are done. I have taken lots of interiors apart for upgrade/fixes and newer Toyotas are super easy compared to the old fasteners. You can probably find a YT video where someone shows how to do that, which is what I usually do.
Jeff11
Jeff
Pittsburgh
Excellent. Thank you! Good to know that even if a decent amount of disassembly is required, it shouldn't be bad.
TRD Jon did a video where he had to take the dash apart on his Tundra and commented on how everything just snaps together and how that made working inside our trucks easy. That is what I have found too. Good luck!
Longpatterned
Tim
New Orleans, LA
Plexus is something that has worked for me but not for deep scratches.
