Does the snorkel present a problem for ditch lights on a Trailhunter?
SmokyMtnTaco
Rob
East TN
smokymtntaco.com
2025 Toyota Tacoma Trailhunter, 2018 Toyota Tacoma TRD Sport
It does and I have a solution on installing these 5 inch LED Driving Pods with Ditch Light Side Shooters, what I'm calling hulked out ditch lights!
2025 Tacoma Trailhunter Ditch Light Problem SOLVED!
2024 Tacoma Does the snorkel present a problem for ditch lights on a Trailhunter? 2025 Tacoma Trailhunter Ditch Light Problem SOLVED!
airxmarshall
Marshall
Utah
2024 Tacoma Trailhunter
I put some rough country 3" lights on, the clearance is extremely close. I had to angle them correctly to fit, but they work! The plug and play with the aux buttons was super easy, I just had to do some surgery on the wiring harness since I have DRLs in the ditch lights. I used aux 1 and 3 to separate the DRL and lights so I can operate them separately and together.
TFOUTS
Timothy
Northwest Florida
I installed Rigid mounts and white(marine) Rigid pods, SPV harness connected to aux2. To open the hood I have to turn the right pod facing the left pod for clearance at the back of the pod when close to the snorkel with the hood up. I carry a small box wrench in the truck to loosen and tighten the pod to turn.
DeadSetMonkey
Denver, CO
For me.
Rigid D-SS Pro lights and Rigid A-Pillar bracket did not clear snorkel.
But D-SS Pro lights and Cali Raised Ditch Light bracket did clear.
