Eibach 24+ Toyota Tacoma Stage 2 Pro Truck Lift Kit - Panda Motorworks
Aleah@PandaMotorworks
aleah
saint peters missouri
2021 ford bronco
PRO-TRUCK-LIFT Stage 2 Coilover Suspension System
Take your Tacoma's suspension to the next level with the Eibach PRO-TRUCK-LIFT KIT (STAGE 2), engineered for precision performance both on and off the road. This advanced system features threaded height-adjustable front coilovers, offering customizable ride height, and utilizes the same high-performance rear shocks as the STAGE 1 setup for consistent handling across terrains.
The PRO-TRUCK-COILOVER 2.0s boast an extended travel monotube design with variable force valving, delivering superior control on highways and unmatched traction when tackling off-road trails. Compatible with Eibach’s championship-winning ERO Off-Road Race Springs, this system allows for flexible tuning to accommodate everything from factory-weight vehicles to fully loaded off-road rigs.
Specifications
Championship-Winning Performance: Eibach’s top-quality suspension utilizes race-proven technology for unmatched durability and handling.
Balanced Ride Quality: Designed to deliver superior off-road capability while maintaining exceptional on-road comfort.
Front Lift Capability: Fine-tune your setup with up to +2.5" of front ride height adjustment for optimal clearance and performance.
Rear Lift Capability: Performance shocks accommodate up to +1.5" of lift for a balanced setup.
Installation: Pre-assembled coilovers ensure a hassle-free, direct bolt-on installation, with factory-level rear ride height right out of the box.
Seamless Compatibility: Built to work seamlessly with OEM control arms, maintaining durability without accelerating wear on OEM bushings and ball joints.
Full Suspension Upgrade: The kit features front PTC 2.0 Coilovers, rear PRO-LIFT-KIT springs, and PRO-TRUCK Sport shocks, delivering a balanced lift and superior handling.
Fitment: 2024 Toyota Tacoma, 2025 Toyota Tacoma
Made in the USA: Manufactured by Eibach, ensuring top-tier craftsmanship and durability.
Limited Lifetime Warranty: Backed by Eibach for long-term reliability and performance.
2024 Tacoma Eibach 24+ Toyota Tacoma Stage 2 Pro Truck Lift Kit - Panda Motorworks eibach-eibach-24-toyota-tacoma-stage-2-pro-truck-lift-kit-eibe86-82-105-01-22-panda-motorworks
aleah
2021 ford bronco
Interested in this setup? Shoot me a message and I may be able to hook you up with a forum exclusive discount! Happy to answer any questions you may have as well!
