Taco Azul
With the weather cooling down I got a couple tires showing low psi. No problem, I’ve got a compressor in the bed! Except when I went to use it nothing happens. It will not turn on. I’ve used it a few times before with no issues.
So I wanted to check for a blown fuse. I checked the fuse box under the hood and there are a LOT of fuses, but none marked for the compressor. Does anyone know where that fuse is?
