Joe650
Joe
Wasilla, Alaska
Excellent write up. Everything looks great. I installed my own raptor lights and wired them into INJ in the fuse box. I noticed the other day they come on randomly. They'll stay on maybe 1-2 minutes and they did that a few times while I was at work. I plan to get some fang lights in the very near future so imagine if I wire them up that way they'll randomly come on. I installed some ditch lights as well and used the aux button that came with them and they work great. I live in Alaska and in the winter, the more lights the better when you're driving on roads with little traffic. The ditch lights already saved me from hitting a moose that I probably would not have seen without them.
gofastdan
gofastdan
Yeah, the INJ fuse has random power going to it, even when the truck is powered off. Likely all the other fuses do as well. The way I'm running everything through a gang box switch eliminates the issue of lights flashing on and off, but it also means I have to manually turn on the switch every time I start the truck, so from that perspective it's no different than using one of the factory aux switches which is how I originally connected my ditch lights prior to buying the switch box.
