RPM jump when stopped on an incline?
Burgi
NC
24 Taco
I have 13k miles on my 24 Tacoma. In the last couple days I noticed that whenever I’m stopped on an incline, my RPMs jump up to about 1100rpm. Usually when I’m idling on flat ground it’s around 500 rpm.
has anyone else noticed this? What could cause this?
Captain O
murrieta, ca
2024 Toyota Tacoma TRD Sport 4X4
Hi,
It's an incline hold feature when the transmission is in drive it raises ther idle to keep you from rolling backwards when you transition from brake to throttle on a hillside. It's in the owner's manual.
Cheers,
PO
Gfenza89
Gary
2022 tacoma sr5
Hi,
Cheers,
PO
I’ve never noticed my truck doing that
Burgi
NC
24 Taco
Hi,
Cheers,
PO
interesting. Does this apply to the automatic transmission?
Captain O
murrieta, ca
Yes. The automatic transmission does it when the truck is pitched uphill.
Burgi
NC
24 Taco
definitely makes sense. I just poured over the manual and cannot find it. What section is this in?
Captain O
murrieta, ca
Hill Start Assist Control. Page 421.
■ Hill-start assist control
Helps to reduce the backward
movement of the vehicle when
starting on an uphill
Cheers,
PO
Burgi
NC
24 Taco
Cheers,
PO
says it has to the with the brake, nothing about increasing the RPM
Burgi
NC
24 Taco
How steep of an incline are we talking about? Yes I’ll absolutely pay attention
Like 10+ degrees or so. The TRDs have a menu in the display that will show you pitch and what kind of angles you're sitting at. Not sure if the SR5 also has this.
Gfenza89
Gary
2022 tacoma sr5
My sr5 has that feature too . I stop on a decent incline going home daily but I’ve never heard the engine idle up while in drive stopped. I’ll check tonight
