What's in the center console under the dash ??
Canufixit
Canu
New England
2025 sr DC 4x
What is behind the Tacoma 2024 2025 center console USB c charger /12v outlet panel?
tgrneal
Aaron
Huntsville, AL
Tacoma Trailhunter
You mean in front of shifter under the infotainment system? Other than wire harnesses? I’m not sure but I’m curious now.
Canufixit
Canu
New England
2025 sr DC 4x
Yes ! and also the opposite / rear end of the Center console as well. There appears to be a lot of unused space between the back of the center console storage hole and the rear of the console.
bobinoregon
Bob
oregon
2025 Taco
the ECM. (electronic communications module) lives there. It phones home on you whether you want it to or not.
john170950
There is a very detailed how to on this site that tells you how to trick it to think its out cell tower range.
I didn't bookmark it but should be easy to find
BrokeYota
North Idaho
2025 Tacoma SR (Poverty Edition)
The back end of the center console houses the power inverter (if equipped). It's a good amount of space if you don't have one. I'm adding an aftermarket inverter there and plan to do a write-up.
