Dongar
Norcal
What's up T4G!
I thought I'd start posting on the boards again to keep my mind off of international trade (PS Dongar is owned and operated by US-born car enthusiasts in a multi-generational Tacoma family haha, but leans on external-US factories).
Thought you guys would like my newest product... a USB-C power adapter (capable of 5V/9V/12V USB-C output, overcurrent/overvoltage protection, etc.) that hooks up to your lane trace sensor computer. (I bet right now you're like "Is that safe??" See write-up and testing in the follow-up post). The 16-pin connectors that piggy back onto the TSS 3.0 lane trace system are authentic TE parts (unlike all the garbage from fitcamx / fitdvr).
USB-C module is engineered in-house by our talented EE out in Europe and isn't some repurposed generic USB module found in a cigarette lighter. For a USB module, this thing is over-engineered and capable of up to 18W output, fine-tuned and field-tested for optimal heat performance.
Harness + Dongar 5/9/12V USB-C module
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) IMG_2904 (Large).JPEG
Plugged into TSS 3.0 Lane Trace system.. TE connectors means a true OEM feel and click.
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) IMG_2910 (Large).JPEG
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1744846269001-u2
Instruction Manual Preview
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1744848418254-63
Field testing in a 2025 RAV4 (TSS2.5) powering the brand new Uniden R8W radar detector at its native 12V with a USB-C to RJ11 cable:
Dongar
Dongar
Norcal
April 16, 2025:
Draft disclaimer write-up for the instruction manual:
Important Disclaimer – Lane-Trace System Power Adapter
Fuse Protection and Low Current Draw
The lane-trace power circuit is protected by a dedicated fuse in the vehicle’s fuse box (just like your other accessory circuits). This fuse acts as a built-in safety mechanism. In the unlikely event of a fault (such as a short or overload), the fuse will blow and cut power to prevent any damage – safeguarding your vehicle’s wiring and electronics. During our testing, we verified that the adapter’s power draw remains well within safe limits for the circuit. We used a fuse-to-multimeter adapter together with a USB load tester to simulate a constant 1.5 A @ 12 V USB-C device load on the adapter. The measured current at the fuse box was less than 2.5 A (the test load and everything else on that circuit, combined) with no large transients observed, even when activating or deactivating lane trace and features. This low amperage confirms that the additional load is minor, placing little strain on the existing circuit. In real-world terms, a 1.5 A draw at 12 V is roughly 18 watts – comparable to a standard car USB charger or a couple of interior LED bulbs. The factory fuse for the lane-trace system is rated well above this level, so normal operation stays comfortably below the fuse threshold. The result of our load test demonstrates that using this adapter has a negligible impact on your vehicle’s electrical system. Its supplying power within the margins that Toyota/Lexus has already provided for. We emphasize that if anything does go wrong (for example, a direct short in the adapter or connected device), the most likely outcome is simply a blown fuse – an event the car is designed to handle by design, with no further damage downstream. Replacing the fuse (and addressing whatever caused it to blow) would restore the circuit to normal. The adapter also has built-in over-current and over-voltage protection, ensuring a second layer of safety for your peace of mind.
Vehicle Alerts as an Additional Safety Net
Toyota and Lexus vehicles are engineered with robust self-diagnostic features. In the event of any malfunction or abnormality in the lane-trace assist system’s operation (for instance, if the camera were to lose power or a fuse blows), the vehicle will immediately alert the driver via dashboard warnings or messages. The instrument cluster’s multi-information display is programmed to show warnings for any system malfunctions so if the lane-trace camera or its power supply is ever compromised, you will get a clear, noticeable warning (such as a “System Malfunction” or similar message accompanied by various status symbols). This provides an extra margin of safety: you would know right away if something isn’t functioning as expected. In our scenario, because the adapter does not affect data lines and only taps power, a malfunction would typically only occur in extreme cases like a short circuit causing a fuse to blow. Should that happen, the lane-trace system would stop receiving power and the car would promptly display a fault alert for the driver. Address the issue (e.g. replace the fuse or remove the adapter) or consult your dealer before continuing to operate the vehicle.
Example Warning Messages. Observed when the fuse pops or the harness connection fails:
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1744847088041-jm
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1744847088074-vw
rougesix29
Oregon
2024 Toyota Tacoma sr5
Bought the same setup for mine. Very easy install and love not having plug going below radio.
Dongar
Dongar
Norcal
April 18 updates!
I wanted to do some data-logging to see how much fuse capacity was overhead... it can seem sketchy plugging something directly into the TSS Lane Trace assist, but I've been wanting to demonstrate why it isn't as risky as you think... some of the companies that have cloned my products (FitDVR / FitCamX in particular) have sold products that plug into TSS for the last couple of years. I've wanted to do this for a while, but because I'm in the USA🦅I have to worry about things like getting sued or blamed for selling something:punch: whereas they don't because they're 100% based in China.
Anyways, I hacked together a shorty RJ11-to USBC cable using a generic USB-C PD trigger cable:
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1745015418318-y6
Then, hooked up my Fluke 289 logging multimeter (greatest dmm ever made imo) to monitor and log load on the circuit using a ESI Fuse Buddy 301M:
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1745015387893-su
2024 Tacoma Powering radar (and other gadgets) from TSS. Dongar preview (USB-C power adapter that hooks up to your lane trace sensor computer) 1745015485037-f
The circuit, which powers the TSS Lane Trace system, reads ~.56A. Adding the radar bumped it up to ~1.0A at rest... Plenty below the fuse’s 10A rating:
All TSS features like adaptive cruise control and lane trace assist work normally 🤷‍♂️. Blowing the fuse (or ripping it out) while driving produces a 'system malfunction error' on the instrument cluster and TSS functions stop. Everything returns to normal after replacing the fuse. Testing will continue using higher loads like multi-channel dashcams or load simulators at the USB module (which we already added overvoltage & overcurrent protection features) to see if anything happens.
Spoiler alert: nothing happens, but thought the community would like to see it in action! In conclusion, using the plug at the Toyota Safety Sense lane trace system is a super convenient dashcam powering solution for trim levels that don't come with an autodimming mirror circuit (or wiring provisions for the OEM dashcam) from the factory... TSS has been standard equipment on all Toyotas in USA/Canada for the last 4-5 years so I'm happy to say we have an easy and low-risk dashcam install solution for any new Toyota/Lexus out there 😊
