CATOY
NorCal
Here's are some pictures and video of the fuel tank on my 5" bed Off Road, doesn't appear to give much space to install a larger tank. The exhaust is routed closely to one end and the rear axle is close in the back. I am assuming that there may be more room on the long bed model.
Undercarriage Video:
Photos:
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4902
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4903
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4904
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4905
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4906
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4907
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4908
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4909
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4910
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4911
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4912
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4913
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4914
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4915
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4916
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4917
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4918
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4919
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4920
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4921
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_4922
Mrknowitall
SE MI
20 Silverado, 22 XV
With a muffler delete/exhaust re-route, there'd be some space for a sub-tank on the driver side.
CATOY
CATOY
NorCal
Here are some more pictures I took today of the underside of the truck trying to show the limitations of adding a larger fuel tank. You can see that there's no additional room in the rear as the rear axle would be in the way and the front is limited by the exhaust. You would have to make some serious changes to the down pipe of the exhaust to reroute to make additional room to increase the length of the tank. All tank and other guards on the underside of the Off Road are a plastic material and would only protect those items from scratches and not dents or punctures. 95% of owners will probably never need to worry about this, aftermarket skid plates will most likely
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5410
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5413
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5414
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5416
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5418
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5419
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5420
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5421
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5422
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5423
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5425
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5427
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5429
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5430
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5436
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5440
2024 Tacoma 2024 Tacoma Fuel Tank Size and room for swap / expansion (underbody undercarriage video & photos) IMG_5441
be available soon for the other 5%.
andrewleader
Andrew
Washington State
Is there any body lean with a full tank of gas like there used to be on the 3rd gens? I noticed it seems like now the battery and fuel tank are both on the passenger side (whereas sounds like it used to be on drivers side).
