kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
Just finished installing the lift. Went with king shocks, 600lb preload in the front. Icon billet UCAs, king rear sway bar link, icon billet upper and lower trailing arms. Just waiting for icon to release the rear springs to get rid of the slight rake. Toyo open country RT 295/75/17 rubs a little with the +10 offset
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 IMG_0076
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 IMG_0077
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 IMG_0078
Lonewolf90
DFW
Thats an awesome setup. What Bumper do you have on it, is that the CBI?
I was looking into it but put it on hold since I noticed they are coming out with a simpler one soon. Curious as well what winch setup you got and if you had to relocate the control box? I'm super OCD and freaks me out to cut the bumper and the lines aren't good.
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
It’s addictive desert designs manufactured here in Phoenix. I have a warn evo 10k
apryakhin
Art
CA
That's the most amazing setup I have seen so far! I have TRD Sport in exact same color and haven't pulled the trigger on installing anything. How much was the Kings suspension cost + installation? Did you do any lift? I probably won't pull the trigger on everything just yet but can get at least started with suspension. Do you think that would make sense?
apryakhin
Art
CA
@kefferjoe Would it be possible for you to just provide some links on what parts you bought and installed for suspension? I see you have some ICON in-front etc. I would appreciate if that way could probably just place similar order. Thanks
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
I did the king 2.5 with adjusters on the front and rear (you have to get the rear sway bar links as well):
https://kingshocks.com/i-30508060-25001-408a-2024-toyota-tacoma-2-5-front-coilover.html?q=
I did Icon UCAs, Track Bar, Rear Upper and Lower Trailing Arms:
https://www.iconvehicledynamics.com...billet-upper-control-arms-w--delta-joint-pro/
https://www.iconvehicledynamics.com...-tacoma-rear-billet-adjustable-track-bar-kit/
https://www.iconvehicledynamics.com...024-toyota-tacoma-rear-billet-lower-link-kit/
https://www.iconvehicledynamics.com...024-toyota-tacoma-rear-billet-upper-link-kit/
Kit was around 8-9k. Install was a lot easier on this gen.
I am still waiting for ICON to release rear springs.
Taconatron
nathan
2024 tacoma
Where did it rub? Was it an easy part to trim?
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
A little bit in the rear only on full turns pretty much went away when I adjusted preload on the kings although it may rub when I’m full turn off roading
Taconatron
nathan
2024 tacoma
34s with positive offset and a 2.5 lift rubbing seems wrong. I believe you but everything up until you says they will clear no problem. Crazy.
Tacocho
Alex
Portland, OR
Those are SCS wheels so they’re probably
(17x8.5-10)
MERAKIAUTOWORKS
Joshua
Anaheim, CA
Baller setup, props to you, looks amazing.
-Josh
CaliTaco64
Hugo
2024 Tacoma trd off road
Do you get any weird clunking or noise when pulling into a steep driveway at full flex of the steering?
