capttim
Tim
Gen4@2024
2024 Trailhunter
We use our truck to overland. For what it may be worth I want to share my recent battery auxiliary battery installation.
I used a 120AHr, Kickass AGM deep cycle. The battery was chosen for its narrow footprint. Charging underway is provided via a Victron 12.12.30 DC-DC charger powered by the truck. I provided for 2 SAE import plugs ( for solar panels that have independent regulation and one input controlled by a Victron MPPT 75/15 solar controller. I provided for a 12 vdc outlet plug from the aux battery to supplement the factory 12vdc outlet powered by the truck starting battery. Finally, a rotary cross over switch was installed. The default position is OFF. It is available to jump the starting battery if needed.
gofastdan
Nice set up. Can you charge the battery from both alternator and solar at the same time or do you have some sort of switch to only charge from one or the other (automatically or manually switched)?
When I was looking for a solution my primary concern was I wanted to charge from solar whenever it was available but then supplement that with alternator charging whenever the truck was running. I didn't want to have to remember to switch back and forth and my solar generator (Ecoflow Delta 2) only had one dc input. I could have used a couple of relays and created some sort of break-before-make type circuit but that seemed like a pretty inelegant solution. I ended up (long story) with the ETaker F2000 and am quite happy with it.
I realize I'm using more of an all-in-one solution as opposed to your a la carte approach but I can see myself moving in the direction you've taken at some point.
DeadSetMonkey
Denver, CO
Can you please describe where you are tapping into alternator power?
Did you make a diagram of your install? Love to see a schmatic?
capttim
Tim
Gen4@2024
2024 Trailhunter
Several reasons. My background is running boats with AGM and or Gel. With good charge control I usually replace these batteries on a 7 year cycle. So for my use AGM is more cost efficient. On my Gen 3 I sold the truck with a 5 year old AGM and it was strong. The Victron DCDC allows very precise charge control
MY PANELS ARE NOT PERMANENTLY MOUNTED SO I DID NOT DEAL WITH ISSUE YOU RAISE. WHILE ON ROAD I WILL RUN THE ARB FREEZER OFF THE 110V / INVERTER BUT ALSO HAVE THE FREEZER PLUGGED IN TO THE 12 VDC AUX OUTLET. THE FREEZER DEFAULTS TO 110V IF AVAILABLE. BECAUSE OF THE HIGH TEMPS WE SOMETIMES TRAVEL IN-- I PROVIVDED FOR 3 SOLAR INPUTS. ALSO - WITH 10 GA CABLES I CAN RUN PANELS INTO THE SUN BUT HAVE RIG IN SHADE IF IT CAN BE FOUND
capttim
Tim
Gen4@2024
2024 Trailhunter
I DID NOT DRAW A PLAN. I DID THE COMPLETE INSTALLATION-- EXCEPT FOR THE DC/DC CHARGER. ON THE TH AND OTHER HYRIDS THERE IS NO ALTERNATOR AND THE 12 V START BATTERY IS UNDER REAR SEAT AND IS CHARGED OFF STEP DOWN FROM TRACTION BATTERY. FRANKLY I HAD THE DEALER WIRE IN THE VICTRON DC-DC CHARGER BECAUSE I WANT NO BLOW BACK FROM TOYOTA THAT I DID SOMETHING WRONG AND WANTED NO ARGUMENT ABOUT THE WARRANTY BEING IN FULL FORCE. I POSTED EARLIER ABOUT WHAT FOLKS WERE DOING TO CHARGE AUX BATTERIES AND DIDNT GET MUCH INFO
jsuber
juke
Jls297#40601
For those looking to do a DC to DC charging system can take a look at this product by LiTime on Amazon I use a lot of their stuff and will post my system next week.
JoeMongo
Jonathan
SF Bay Area
2024 TRD Offroad, Premium, MT
Looks like good work to me (very experienced EE) with a small exception which I am pretty sure that you have covered already.
You probably don't allow any loose loads in the bed of your truck.
j.
k1m
Nathanial
usa
Would you be willing to take a picture of the termination of the positive input for the Victron Dc/Dc charger? Is it connected directly to the positive terminal of the battery or is it connected to one of the alternate taps that are under the red plastic cover that is on the positive side of the battery? Or is it connected in another place?
I have poked around and on the side of the battery where at least some of the positive wiring terminates there appears to be an unused post terminal and I was wondering if that is what they used for the connection.
Thank you for you help.
