AUX Switches easy to use / hook-up!
kennyk
Kenneth
Renfrew, PA
2024 Toyota Tacoma
Do you have any pictures or part numbers of the items you used?
Milz
Altoona, PA
2024 Tacoma TRD Off Road
The pigtails came with the truck, I have everything zip tied so I can’t get a good pic. Great YouTube video on this link shows everything:
WFORich
Rich
Cincinnati
24 Tacoma Sport, 2018 Mazda 6, 2 Acura RSX
My 24 sport came with 3 pigtails in the glove box.
One hooks to plug near filler neck of windshield washer tank and has 4 bare wires on the other end to hook to 3 things you want to power (from 3 aux switches)
Black AUX 1 15Amp fuse
Green AUX 2 10amp fuse
White AUX 3 5 amp fuse
White w Black stripe - Ground
The second pigtail is nearly identical to the first but only has 3 bare wires (ground and two hot from switches, then on the black wire (aux 1 )it has a plug that plugs in to the harness at the bottom of the washer tank neck and sends power to the back somewhere near the bumper.
The third pigtail (one black wire and ground ) then plugs into the harness in the back frame of the truck to power something in the rear.
pic and specs here....https://raveoffroad.com/products/2024-tacoma-aux-switches-harness-kit
BuriedFriend
Stevie
texas
24 Tacoma TRD Pro
That's good info and all, but for a baja S8 40" light bar it pulls 16amps much less onx6+ pulling over 26 amps. I'm guessing for things like this you would have to run your own wiring. Please correct me if I'm wrong. I'm new to this light bar and preinstalled plug stuff.
BuriedFriend
Stevie
texas
24 Tacoma TRD Pro
Just got my new Taco TRD Off Road last week. Installed some grille lights and used the AUX3 switch. What an easy process, plug & play at its finest! Great job Toyota!
What light did you install and how many amps does it draw?
UT
I'm buying the Heretic 20" for the TH grille I bought recently. It draws 13.8, so Aux wiring is fine. That and replacing my OR fogs with some heretics as well.
