Anyone installed DRL fog light “Fang Lights”?
Jakedawgy
Rock
Ottawa, Canada
Just saw this on YouTube today. Fang lights installation is on a Tundra but it may be relevant for the Tacoma as well? Maybe Toyota uses the same color wires in the Tacoma?
UT
I’m wondering if you could access the “fang” “cover, front bumper hole” (part #52127G) from under the bumper peeling back the felt wheel liner and access from above the headlight. I really don’t want to take the bumper off.
I just replaced my grille, shutter, and one fang. Nope with the way the tabs are, it would be almost impossible to get them out without removing the front.
Good news is that once you learn the process it's an easy removal and replacement. Putting it back on was super easy compared to the initial learning process of taking it off.
PatrickO
Patrick
Hawaii
2024 Toyota Tacoma
I installed the fang fog lights using the Tundra’s video
Did yours come with a red wire that goes to accessory power or straight to the battery? Mine goes to accessory and I still haven't installed it. Does anyone know if I can tap any other power instead of going to the fuse box in the cabin?
Suzay
Hawaii
2024 Tacoma sport
Red wire is power you can tap into the turn signal beige/pink wire. So red (power)and yellow (turn signal) wires together tapped to the turn signal. But it’s best to route the red to the fuse box using add a fuse 10amp
PatrickO
Patrick
Hawaii
2024 Toyota Tacoma
Thanks! Will do that once I have time to install.
