MP3 not working out
Shannon
Shannon
Aiken sc
21 TRD Sport 4wd
I want to play music from my zume. I checked on line and read where I was to get a verbatim 16 mb flash drive along with an adapter... make sure the flash driver was formatted to FAT32. I took the music on my Zume and moved it window media player and then copied to the flash drive. I then took it to my truck, plugged it in and turned on the truck... the truck never recognized the flash drive. So after doing everything I was told to do, and it didn't work, does anyone have any suggestions as to what I should do now? I appreciate any advice. Thanks
soupy1234
Show Low AZ
2024 Tacoma OR Long Bed
Forest Moon
Michael
MA
2024 OR Supersonic Red MT
If you have the 14” screen you have to use the usb port on the right side of the screen. I believe the two under the head unit are power only. I am currently using a 16gb drive and it works fine.
timetoeatpotatoes
A
CA
2024 Trailhunter
I've got a 512GB type-c in there and it works. I had to specifically format it to fat32, exfat did not work. had to use "Fat32 Format tool". some ancient app since windows wont do regular fat32.
