kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
Do you get any weird clunking or noise when pulling into a steep driveway at full flex of the steering?
it means your collars are adjusted for too much lift. There is a term for it but I forget maybe binding? Move the collars up and it will go away also install a diff drop kit from icon
CaliTaco64
Hugo
2024 Tacoma trd off road
I don't have collars.
I have the king 2.5 king suspension. Only thing is I don't have the front sway bar links and the suspension was set at 2 1/4 height.
Thoughts ? What is your suspensions set at ?
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 20241208_115251
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 20241204_160523
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
So you should have the sway bar links I donā€™t even think they would sell me the king shocks without buying the sway bar links. I donā€™t quite know what the are set up at but I know when I had the preload collar adjusted too low I would get a popping up and down on full lock turns
Catfish
Adrian
Stockton Ca
4th Gen Oxide Bronze
Icon has rear springs at 1.25ā€ of lift. Why exactly do you want it to be leveled? You do know that as soon as you load anything in the bed, it will sag. Right? thatā€™s what a little Rake is for.
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
some of us went a little higher and a stiffer spring rate with the tundra rear springs šŸ˜‰ but I also agree. Take the preload down and that popping will go away
Catfish
Adrian
Stockton Ca
I myself went with C59-819V from Dobinons. I netted 2.25ā€ of lift in the rear and have 400lbs in the bed right now.
2024 Tacoma 2024 Tacoma on King/Icon Suspension Kit + Toyo Open Country RT 295/75/17 IMG_2088
kefferjoe
Joseph
Tempe, AZ
2017 Tacoma TRD OR
Is that a smart cap? I just ordered one. Reason why I went with the tundra 1.5ā€ springs. It also gave me about 2.25ā€ in the rear.
CaliTaco64
Hugo
I just installed the front links this past weekend. And it's still popping.
Did yours stop ?
CaliTaco64
Hugo
Went to yhe stop today and took the preload off to no preload. And it's still popping.
Called King and they said to bring it in so they can inspect it and make sure the shop didn't do something wrong
CaliTaco64
Hugo
Any weird noises when entering a steep driveway at around full lock of steering ?
