Factory mud flaps should be replaced by dealer
saerandy
Randy
Richmond, VA
2024 SR5
That was me with that Canadian mudflap quote.
The biggest thing is that they are wider.
Here is the part number of you’re interested in trying to track them down.
Note that these are installed on a TH and they stick out as far as the wider flares that come on that model.
PK389-35R00-P1 is the part number for the set of 4
Franko Manini
Frank
Victoria, BC CANADA
I don’t think that’s correct. There is another set that is slightly narrower that ends in R00. The wide ones - they fit the wider flares of the TH and Pro end in R50. The set part number is PK389-35R50-P1.
myrr
WA
24 Trailhunter
I should have PK389-35R50-P1 this week for my TH. Looking forward to the correct mudflaps.
saerandy
Randy
Richmond, VA
2024 SR5
I think you’re right. I didn’t consider that there might be three different mudflaps. Maybe there are even more? The first is the one that OP shows. Very narrow. The ones I posted are wider, but it looks like as wide as the normal flare, and then the ones you posted l
ook like they are even wider for those that have bolt-on flares. It would be nice if Toyota had better documentation on this but I guess we’ll have to do it here ourselves.
