TH build w CBI products-Prinsu rack, Sliders, Covert Bumper
Bcphoto3
Bill
Oak Ridge, TN
Started the build on my TH with Method 703 Bronze wheels and Falken AT4W tires (285/70/r17). Next took off OEM Rock Rails (no step and not as protective as I wanted) and put on CBI Overland bolt on Rock sliders (powder coat/ DOM/ double cab 5’/ kickouts). Had Asheville Vehicle Outfitters install Prinsu rack with Rigid Light Bar. Waiting for CBI Covert bumper and AluCab Contour canopy to come in. Only difficulty so far was trying to bolt on the Rock Sliders.. Dont know if there is some manufacturing variance, but there was small box hanging off frame in rear that prevented sliders from going into place. Fixed with small 1/3 inch triangle cut out of both sides of box and sliders mounted just fine.
Could you take a front photo so we can see the tires from the front - also these are the +35 offset wheels I presume? Looks good.
Bcphoto3
Bcphoto3
Bill
Oak Ridge, TN
Were those sliders for a hybrid?
Most defintely since my ride is a Trailhunter. Love the sliders, but not easily attached as not completely bolt on. Had to do some cutting work on pieces hanging off the frame. Holidays interfered but will be having a conversation with CBI within next couple of days.
px3_taco
Michigan
Gotcha, was just curious as I know a lot of companies have separate listings for each, wasn't sure if CBI did.
GronzoTaco
Nevada
2024 Tacoma TRD Off-Road i-FORCE MAX
I got the CBI bolt-on sliders for my hybrid TRD Off-Road and have the same issue with the rear plate hitting the piece coming off the frame. Another issue with mine is on the front plate where the bolt is supposed to go through the frame, there is a crossmember on the inner side of the frame so the bolt can't make it through. That leaves only two bolts on the front plate instead of three. CBI clearly has not confirmed fitment for the Hybrid and makes no mention anywhere on their website or install instructions. This is pretty disappointing after spending $400 for shipping...
