Rough Country RC Neoprene seat covers
emerica243
Matt
PA
Fusion
FYI. Wasted some money today on these. If you have electric seats then the covers in the front will not fit correctly nor be tight and from fitting because the straps cannot be connected underneath. There is an OEM shield under the seat that hides/protects all the wiring and prevents the tucked buckles from being able to be gotten to and connected.
There are some nylon type straps that probably can be fanangled to get them unhooked but it's so damn tight back there.. Also it's lame that RC doesn't have this type of stuff covered in an install video. With no instructions it's lame to market these for this vehicle.
Brian2011
MASS
2024 Trail hunter
They fit perfectly fine, Raise the seat all the way up and you can easily get the straps over the bars without issues.
2024 Tacoma Rough Country RC Neoprene seat covers 461598914_2325979091094899_5953964312333475599_n
emerica243
Matt
PA
Fusion
What do you mean by straps over the bar? I have a big cover underneath the seat from the back. Even with my seat all the way up u can't see from the back how to get that cover out of the way to get to the straps.
Brian2011
MASS
2024 Trail hunter
you have to unclip that flap there on stretchy cord connected to the seat, unclip that and bingo
emerica243
Matt
PA
Fusion
And for the 3 clips\straps, do you bring them out the side of that flap and then reattach the flap? Obviously the only other option is rip\poke holes in the flap equally across and then put the flap back up.
Brian2011
MASS
2024 Trail hunter
no the 3 straps come thru the back of the seat, once that flap is unclipped you connect the 3 straps for the seat cover and you push that flap up into the rear seat cover you see nothing and cut nothing
