Describe your transmission behavior.
Burgi
NC
24 Taco
Well, now I am getting a surging after a cold start, 30 mph with a very small load, level road, no acceleration.
i also get this sometimes around the same speed. It's only happened a couple times and always first thing in the morning on colder days.
Burgi
NC
24 Taco
@Burgi, @tacorancher, @inlandsmog do the engine RPMs stay the same when that happens? I'm wondering if that surge is caused by the ECU or by the transmission. AFAIK my truck has never done that under any circumstances.
I haven't paid too much attention to it. I just figured it needs a little time to warm up. I'm not too concerned about any of it, I have the 7yr 100k warranty and if my transmission is going to blow up it will most likely happen before then.
While your engine is warming up it might just be the ECU adding revs at that gear/road speed and not the transmission at all. Or it could be when the torque converter locks, and maybe not even a problem.
I didn't get an extended warranty because none of my previous Toyotas needed one. I probably should have gotten that for this truck when I purchased it. I think when I get near the end of the drivetrain warranty I will ether extend it or get another truck. I am no longer worrying about my truck either. The transmission will either fail or not and that is out of my control.
I'm still loving my truck and having fun with it on every drive and it sounds like you are doing the same.
