Auxiliary pigtails
Biggs1975
Joe
Virginia
2024 Trailhunter
Hey everyone, I bought my Trailhunter back in August and was wondering how many pigtails came with the truck? I found these 2 bags of pigtails. For some reason, I thought there were more. Thanks for any help with this.
2024 Tacoma Auxiliary pigtails 20241220_190217
bking
Bernie
2024 Tacoma TRD Offroad
I think I got 3. Keep in mind, the one pigtail with multiple wires covers all 3 switches. The white wire is ground. I forget which one is which for the others, but there's a diagram. I ended up making DT Ends for each and splitting the ground between them. The pigtail with only 1 wire is to send power to the back of the truck. You connect one power lines to the pigtail and plug it in the small plug.
dvrgz
Los Angeles
Followed up with my dealer to see if my truck was supposed to come with the pigtails. “If it’s not on the window sticker you don’t get them”. They were not. They ain’t cheap.
2024 Tacoma Auxiliary pigtails IMG_8398
bking
Bernie
If you have the switches, it should’ve come with Them. I think I found mine in the glove box. They weren’t on my window sticker either.
dvrgz
Los Angeles
The aux switches didn’t come on my sr5. But I’m going to add some. My truck wasn’t even going to come with floor mats. I pressed the issue at the finance table and they pulled them off another truck. All good though.
2024 Tacoma Auxiliary pigtails IMG_8400
Halifax, NS
2025 TRD Pro
I got 4 on my 2025, I have 4 Aux pre wired switches, they 100% DO come with the truck, that's the point of them
dvrgz
Los Angeles
If your truck has the physical aux buttons they’ll come with the pigtails. My sr5 does not have the physical aux buttons but I plan on adding them. I guess I can continue to push the issue with my dealer but they were pretty stern with if it’s not on the window sticker you don’t get it.
Halifax, NS
2025 TRD Pro
okay yes this makes more sense, if it doesn't have the button then no, my bad
bking
Bernie
Is the wiring there? If not, I would get switches from CaliRaised. They have a ton of them that fit in those OEM spaces and look nice, but they also have things like light bar, ditch, lights, etc., printed on the buttons
dvrgz
Los Angeles
Just ordered some ✅ I’ll report back with what I do with them . Thank you !
