JustDSM
Justin
Ogden, UT
www.overlandtailor.com
2024 Tacoma TRD Offroad
We’re excited to announce an update for 4th Generation Tacoma manual transmission calibrations!
This update specifically targets "Rev-Hang", reducing the throttle hanging effect that many modern manual drivers find frustrating. The result is a more natural and responsive driving experience—better gear transitions, improved drivability, and that connected feel you expect from a manual.
This revision is now live and available at no additional cost to existing customers running our manual tune. If you’re already tuned and want the update, just reach out. And if you haven’t jumped in yet—now’s a great time.
Drive how you were meant to.
- OTT
Tacocho
Alex
Portland, OR
This mod is next on my list! Can you guys speak on OTT and how it affects warranty? I know on the previous gen v6s, there were no warranty issues, what about for the 4cyl turbo?
- OTT
JustDSM
JustDSM
Justin
Ogden, UT
Can the manufacturer void your warrany? Sure! However. We’ve never heard of an issue in our years in business. Dealerships/Technicians don't actively look for aftermarket calibrations (we have an active Master Tech on staff to advise us of the latest policy and procedure). The field level technicians’ diagnostic tools are not able to discern the calibration changes. Certainly, assess your own risk. If I modified something and a part failed due to that, I wouldn't expect or ask Toyota to cover that under a warranty. As lovely as it would be to have zero risk and all the reward, it doesn't exist. That said, we've never seen or heard of an issue with our tuning causing powertrain failures. We work hard to vet our data, we test and validate our work in a diverse range of environments, torture test it on the dyno, and conduct in-house emissions testing with a 5 gas analyzer ensuring our files not only perform as expected on the road, deliver the broadest powerband possible for the given platform while ensuring our platforms meet reasonable basis for not increasing emissions output of the vehicle, etc. Our 3rd Gen 3.5L V6 Calibration has been awarded CARB-EO D-883 making it 50 state legal. the 4th Gen 2.4's are on deck!
When you take your truck in (tuned) here's what the dealer sees when they look at reprogramming history and warranty status. There's no need to unplug obvious devices under the hood or anything like that.
Reprogramming History: Despite over 1000 developmental flashes, no flash is recorded in Toyota's system when using our tools/methods.
Warranty Status: Still fully in-tact, even after delivering the vehicle with the tune installed, to the dealer for the Transmission Debris TSB.
Hope this helps and answers your questions
Tacocho
Alex
Portland, OR
Thank you, this is extremely helpful.
808taco
Ron
Hilo, HI
2024 trd sport MT underground premium
I have a dealer in Kona Hawaii which is an OTT tune partner, specifically told me it will void warranty. You say otherwise. Im a bit confused
JustDSM
JustDSM
Justin
Ogden, UT
Hey, totally fair question—and I appreciate you bringing it up.
First, just to be clear: I’m not here to provide legal advice, and everyone's situation can be different depending on how a vehicle is used, serviced, or modified. That said, here’s where we’re coming from.
There’s no denying that any modification, whether it’s a lift, larger tires, or ECU tuning, can carry some level of warranty implication. That’s true with any manufacturer—Toyota included. If a part fails because of a modification, then yes, they may deny coverage for that specific failure. But that’s not the same as saying “your entire warranty is void.”
What we’re sharing here—backed by screenshots and experience from over 20,000+ tunes in the field—is that the simple act of tuning alone does not automatically void your warranty. Nor is it something that a tech or service advisor will see flagged in the system. We even had our own tuned truck brought into an unaffiliated dealer for the Transmission Debris TSB. Not only did they perform the service without question, but the warranty record remains untouched.
As for your local dealer saying tuning will void your warranty, that’s unfortunately not uncommon. Some dealerships take a very conservative stance, often out of an abundance of caution or based on internal policy. That doesn’t necessarily mean Toyota corporate has flagged the vehicle or that your warranty is globally voided. Again, context matters.
We’re not saying there’s zero risk. Catastrophic failures can happen even on bone-stock trucks, though they’re very rare. We've never seen an issue caused by our calibrations, but we also test rigorously. Still, it’s up to each owner to evaluate their risk tolerance and make decisions they’re comfortable with.
At the end of the day, we’re just sharing data—not opinion, not speculation. We want to help clear the air in a space that’s getting increasingly crowded with misinformation and hearsay. Hope that helps clarify things a bit.
DialupDavid
Sam
Minnesota
2025 Tacoma TRD PRO
I really respect what you guys bring to the scene.
That said, while the re-flash may not throw a "flag" if there's no software fuses it is 100% detectable if you go down the rabbit hole and a field service engineer goes through your vehicle. Namely if you blow an Engine or Transmission, etc. Toyota is going to want to know what happened to fix in future iterations if it's too big of a question mark with high cost/safety implications. It's not possible to keep the stock checksum from the factory calibration on the ECU if you've tweaked anything in it. Every single platform update to the ECU will have a SHA-256 that Toyota can reference internally and tell it's been modified.
Dealer likely won't go down this rabbit hole, but if you do something crazy and lean out the engine at 5K miles that throws a rod through the hood they will investigate.
MoCat19
Rob
I’ve had the tune for over a month and I have an issue with it loading up around 1800-2200 rpms and blowing black smoke during this window on acceleration . It hesitates and stumbles and then wakes up at 2500rpm. I now have to drive back out to my tuner who is 90 miles away for this to be addressed.
808taco
Ron
Hilo, HI
Any update on your situation?
Banj
Hawaii
2024 Tacoma OR
I ended up going back to Stock. I didn’t feel confident in their ability to make this right.
This is disappointing to hear. I was really considering getting the tune just for the rev hang reduction.
JustDSM
JustDSM
Justin
Ogden, UT
@Banj We've updated our MT files after the individual above had his issue.
After careful review of the data, we made some changes to prohibit manual transmission drivers from lugging the engine at low RPM and high throttle input. We implemented the corrections shortly after and have been running on an updated MT calibration since, which offers no less performance but curtails the boost pressure that can be generated in situations where folks are in a position to lug the engine.
Here's one we did from a gentleman who drove down from Montana to get our calibration at the Texas Toyota Jamboree: https://www.tacoma4g.com/forum/threads/has-anyone-done-the-ott-tune.12091/post-155207
We take what we do very seriously; I'm confident we'll be able to meet your needs.
Best,
Justin
Flat Plane Life
Nick
2019 GT350R
Hey sorry in advance for so many questions - coming from higher hp vehicles, especially in the manual category (cars, diesel trucks) I'm kind of not impressed with this powertrain....does toyota preprogram a break-in period that's less hp?
Could you explain this "rev hang reduction" more? Is this on clutch input? To me the hanging revs on clutch input seem to help the smoothness. It feels like power is cut or limited though on re-applying the throttle. Is this true? In general the most annoying part is the huge jump from 1st to 2nd gear. If I could take off from 2nd more that would be nice.
In addition to the rev hang, do you do any sort of anti-lag programming? I'm assuming the wastegate is electronic? Maybe opening it on no load or clutch input could keep it spinning better?
I'm definitely interested in a tune but don't want to stress the little 4-cyl out either. What safe gains could I get with a stillen airbox and a 93 octane tune?
Thanks in advance
RatInsurance
Andrew
Knoxville
4G Tacoma MT
Thanks in advance
The power cut when the upshifting is present in my truck as well. It makes the pedal borderline unresponsive when trying to upshift (or at least that how it feels to me when I drive). The only fix I found was to use Toyota’s iMT function. On top of reducing that lack of responsiveness when changing gears, it also holds the revs in the right spot when upshifting rather than allowing the RPM’s to drop below the required amount. This makes it easier to drive more consistently and smoothly during that first shift.
The jump from 1st to 2nd is something that plenty of people have complained abt (including me) and doesn’t necessarily have a fix. The ratios compared to most manuals, even truck manuals, is odd. iMT can definitely help with the 1-2 shift but the best thing to do is to rev it to about 3500rpm and practice. It took about 5000 miles to get that shift down properly myself.
For the power conversation It really can depend on loads of things. (Keep in mind i’m no expert, and what I’m abt to say comes from only what i’ve experienced and read online)
1. Heat soaking
These truck respond heavily to changes in temperature like most turbocharged engines. If it is overly hot outside, the turbocharger will usually be slower to produce boost as the hot air is thinner compared to cold. Not only that but the truck will restrict boost and timing in order to maintain proper temperatures and not overheat. If you live somewhere really hot this may be it.
2. Fuel
93 octane. Run it. 4th gen’s can run on 87 octane just fine but the truck will try and reduce engine knock by simply reducing boost pressure. From what I’ve read this can sometimes be about a 5-15% reduction of power. ( which in the Tacoma’s case is abt 230 hp ) Now, that’s probably an over exaggeration but even a 10% decrease in hp for the tacoma would most likely result in it feeling sluggish. I run it not only because it may give me more power but because of a reduced chance of engine knock.
3. Drive mode
If you wanna feel the power put the truck in sport mode. The boost comes quicker (allowing you to feel all 310 lb-ft of tourqe at 2800 rpm) and enhances that mid-shift throttle response. May not help with fuel economy but it puts a smile on my face.
There are definitely plenty more factors that i’m missing that have an effect on everything you’ve listed but I hope what I’ve said helps.
Enjoy your truck and take what i’ve said with a grain of salt. I’m no expert
JustDSM
JustDSM
Justin
Ogden, UT
Thanks in advance
Hey, no worries at all! Good questions and exactly the kind of dialogue that helps others too.
To your first point: there’s no deliberate "de-tuned" break-in mode in the ECU like you might see in some high-performance vehicles. The truck makes its rated output from day one, but perceived power can feel a bit lacking early on due to adaptive learning, heavier-than-expected throttle smoothing, and—frankly—a pretty conservative factory calibration. Also, coming from higher-hp platforms, this 2.4L can definitely feel underwhelming until you start opening it up and removing some of the factory handcuffs.
Our calibration includes rev hang reduction, and you’re right: from the factory, revs tend to hang after clutch input. This behavior is intentional on Toyota’s part, mainly for emissions and idle control. It’s especially noticeable when rowing gears manually because the ECU keeps the throttle cracked open even after you’ve let off the pedal. This slows the RPM drop, which can feel sluggish or disconnected if you’re used to more responsive powertrains.
We address this by tightening the throttle-off decay and optimizing how the ECU responds to clutch input + throttle lift events. It results in a quicker RPM drop, improved rev matching, and a more natural, engaging driving feel—without making shifts jerky. You still get smoothness, just without that artificial delay.
The 1st to 2nd shift is tall and awkward from the factory. The transmission ratios, plus clutch engagement characteristics, make it a bit clunky in stock form. Our calibration can’t change gearing obviously, but with improved torque delivery and throttle control, the shifts can become smoother.
Also, once tuned, you'll find taking off in 2nd is doable for light acceleration situations. It's not something we explicitly program for, but the added low-end torque and cleaner throttle modulation make it easier.
The wastegate is vacuum controlled. While we don’t implement traditional “anti-lag” (in the motorsport sense), we do optimize spool behavior and wastegate strategy to help maintain pressure and improve response after shifts or lift-throttle situations. This is especially helpful in midrange transient conditions where the factory tune pulls back too much. We also reduce unnecessary wastegate preemptive opening during off-throttle, so boost comes back on quicker without compromising safety or spool.
With 93 octane and something like the Stillen airbox (which requires custom MAF scaling), you're looking at safe, repeatable gains in the +30whp range over stock across the entire RPM curve—depending on conditions and fuel quality. We maintain factory safety strategies (knock control, overtemp protection, etc.) but sharpen the response, spool time, and overall driveability. Nothing is pushed beyond reasonable limits.
The OTT tune is designed to bring out the best of the powertrain, not to chase numbers at the cost of durability.
Best,
Justin
