Ghosted_trd
Hey @Discount Tire! Have you got any info on wheel specs? Wheel width, offset and bolt pattern/threads.
Threads are coming soon, in the interim, is there anything specific we could help you with?Hey @Discount Tire! Have you got any info on wheel specs? Wheel width, offset and bolt pattern/threads.
Congrats on your new Taco! Staying with the factory wheels, you should have no problem with fitment. However, if any impact is to be had, It would be slight on the mud flap which can be rectified by a heat mod or removal. Do keep us informed, we need all the real world experience we can get.I have locked down a TRD Sport, it will come with 265/65 R18, and I want to mount 265/70 R18, that is 1/2 inch on left, right, top with 1/2 inch height growth going from 31.5" to 32.6" tires.
Should fit?
Any update? I reserved a Sport MT and thinking the same as far as tires go. Do you plan to lift/level your truck? Would appreciate any updates or thoughts.I have locked down a TRD Sport, it will come with 265/65 R18, and I want to mount 265/70 R18, that is 1/2 inch on left, right, top with 1/2 inch height growth going from 31.5" to 32.6" tires.
Should fit?
