Blackhorn
Gen 3 Taco
285/70R17 BFGoodrich All-Terran T/A KO3 on 17x8.0 ET15 factory style aftermarket wheels.
2024 Tacoma 285/70R17 BFGoodrich KO3 on 17x8 +15 Aftermarket Wheels (2024 Tacoma TRD Off-Road Stock Suspension) DSCF6988
2024 Tacoma 285/70R17 BFGoodrich KO3 on 17x8 +15 Aftermarket Wheels (2024 Tacoma TRD Off-Road Stock Suspension) DSCF7039
2024 Tacoma 285/70R17 BFGoodrich KO3 on 17x8 +15 Aftermarket Wheels (2024 Tacoma TRD Off-Road Stock Suspension) DSCF7036
Was a bit skeptical about the fitment of 33" on 17x8 +15 in the beginning but turned out to be exactly what I was hoping for. The amount of poke is great, if not more.
2024 Tacoma 285/70R17 BFGoodrich KO3 on 17x8 +15 Aftermarket Wheels (2024 Tacoma TRD Off-Road Stock Suspension) DSCF6895
In terms of clearance, it's very tight but no contact. (Picture shows the closest contact point when turning) But I removed the mud flaps, you know, just to be "safe".
No mods (yet). I'll test a few more setups (+25/+35) in the future. I'd say this gen is way more capable of handling things compared to the last gen. Very excited to have it on the road and explore the wild.
Teamchin
Chester Springs, PA
Tacoma Pro
Where did you get the wheels? Can you post a straight side view? Debating if I should go 265 or 285 BFGs
komek
Western Washington
M2 Competition
I’m looking at doing this tire setup for mine when I get it. Is there any way to help that clearance rub point other than removing mud flaps?
Blackhorn
Blackhorn
Gen 3 Taco
There's no rub actually even with the mud flaps on. I just took them off for precautions.
Blackhorn
Blackhorn
Gen 3 Taco
I went +44 and I'm not even close to rubbing with the same size tires. This is on Stock suspension
. I'd imagine a smaller poke would help in that regard
With that offset you probably can go even wider tires!
DELETED MEMBER [fitsofrage88]
Guest
Already a few have been using +25 and even a -38 offset….
komek
Western Washington
M2 Competition
Thanks! This is good to know. I can't find those wheels you got on that site. Link? I love em! Probably my favorite aftermarket wheels on this truck so far.
JustAnotherDingus
Southern CA
Volvo Wagon (for now!)
nice and clean. I dig it. :)
were you able to fit a full size spare of that config under the bed? I know it’s tight back there but I’m curious what maximum tire/wheel size can be stuffed underneath.
Blackhorn
Blackhorn
Gen 3 Taco
Not sure if this forum is allowed to post outside links so I just pm'ed you the link.
Blackhorn
Blackhorn
Gen 3 Taco
PMed...:like:
Moderator: Is it allowed to post outside links on this forum?😂
