BLtheP
I think the one from YouTube is a bit misleading - that one is diff howl and it does sound a bit different but it’s hard to hear. That one’s an automatic though so it definitely isn’t making any manual trans noises. If yours has the whistle like mine then it’ll be fine, as long as the noise doesn’t bother you itself. I drown mine out with radio. The way the gears are ratio’d gets the gear teeth spinning super fast in there when in the OD gears.Thanks. Definitely doesn't do it in 4th, but also the noise seems the same between the video you posted (which I appreciate) and the one I found on youtube who's getting his replaced. I'll just keep an eye on it.
