benjedi420vt
I'm working on this as well. I believe mine is two clicks rear and one click to the right and it sounds...better. The problem with this is it reduces the sound from the front tweeters as well...which you really don't want to do. With all the above said, the sound is very crisp and detailed...it's a quality system. Just need to be able adjust the volume of that center channel. And it most certainly can be adjusted...it's just a matter of Toyota or JBL writing some code to let us adjust it. If enough people complain about maybe they'll do something.If it sounds like its coming from the back then you went to far with the rear fade. It is very possible to balance it nicely. I know this because I did it. Good luck with getting what makes you happy!
