Trailhunter lift options
Dr.Tron
Salt Lake City, UT
Is anyone aware of front and rear lift options that fit the OME Trailhunter suspension? Looking for 1-2" up front and 1-2" in the rear with stiffer spring options for standard load of about 400# extra weight from canopy, rack, boxes, etc. Rear sags 1-1.5" from added weight. I would like to correct the sag and add some additional clearance.
Can't seem to find much of anything that is Trailhunter specific.
Hey guys - need some help here - is it “normal” that the passenger side is a little higher than the driver side? I think half an inch up front. Also, are most folks at around 38-38.5” from center cap to fender as shown in the photo with stick tires on the trail hunter?
2024 Tacoma Trailhunter lift options IMG_5065
Vidman
Rick
Mass
Typical taco lean..most all have it to some degree
ChrisWhaaaat
Western Canada
2024 Tacoma Trailhunter, 2018 4runner limited/turned off-road, 1977 FJ45
I’m also watching this. I’d like to do something like the peak suspension 1” for the front, but I would like to similarly lift the rear around an inch as well. I dont mind the slight rake because i load the truck regularly enough.
I’ve submitted an inquiry with peak suspension and will report back with their response.
