Duce95
Big Deezy
2021 TRD Offroad
@LASFIT It seems there might be a quality issue. The fit on the driver side is horrendous. Passenger side isn’t much better. Did not try the rear seats.
Thoughts?
You need to get them to heat up some to form better. Try leaving them in direct sunlight for an hour and then install.
I’m in Arizona in 115 degrees so mine laid perfectly after a day!
@LASFIT correct?
LASFIT
LASFIT
Ontario. California
www.lasfit.com
Toyota Tacoma 2024
Thoughts?
Hi there,
Thanks for your feedback.
From the picture you sent, it seems that the floor mat comes out of package with some bent or deformed areas, causing it not to lay flat properly.
This likely occurred due to stacking several pieces of mats together during storage and transportation, rather than being a defect in the product.
Could you please expose the driver-side mat and passenger-side to the sun for at least 5-8 hours and give us an update? This should help the mat regain its shape and lay flat properly for installation.
We will follow up in the next few days for the result.
Your sincerely,
Lasfit Team
LASFIT
LASFIT
Ontario. California
www.lasfit.com
Toyota Tacoma 2024
@LASFIT correct?
Yep, please take a try and any other issues please let us know. We will follow them asap.
LASFIT
LASFIT
Ontario. California
www.lasfit.com
Toyota Tacoma 2024
🎉Newly launched! Toyota Tacoma 2024 5FT/6FT Custom Tailgate Mat, providing ultimate care for your beloved car.
Hi there,
We got some feedback for the custom tailgate mat for Tacoma. Here it comes.
💪🏻Perfect Fit
With custom-fit design, it seamlessly matches your Toyota Tacoma 2024 - 2025. Whether it's a 5FT or 6FT model, it can be easily fitted, tailor-made for your vehicle.
🛠Easy Installation and Super Stable
The installation process is effortless and convenient. The screws can perfectly match the original factory ones. No more installation troubles. Once installed, it's stable and safeguards your journey.
🌟High-Quality Material
Adopting TPE raw material, it's not only environmentally friendly but also has excellent wear resistance and anti-slip performance. The scratch-resistant design keeps your car's tailgate looking brand new at all times.
If you want to get more details, please feel free to take a check here.
Fit for Toyota Tacoma 2024 - 2025 5FT/6FT Custom Tailgate Mat
🎉Newly launched! Toyota Tacoma 2024 5FT/6FT Custom Tailgate Mat, providing ultimate care for your beloved car.  💪🏻Perfect Fit With custom-fit design, it seamlessly matches your Toyota Tacoma 2024 - 2025. Whether it's a 5FT or 6FT model, it can be easily fitted, tailor-made for your vehicle.  🛠Easy Installation and Super Stable The installation process is effortless and convenient. The screws can perfectly match the original factory ones. No more installation troubles. Once installed, it's stable and safeguards your journey.  🌟High-Quality Material Adopting TPE raw material, it's not only environmentally friendly but also has excellent wear resistance and anti-slip performance. The scratch-resistant design keeps your car's tailgate looking brand new at all times.  If you want to get more details, please feel free to take a check here. Fit for Toyota Tacoma 2024 - 2025 5FT/6FT Custom Tailgate Mat
Tacocho
Alex
Portland, OR
When are you guys releasing mats for the manual transmission trucks?
Hi there,
💪🏻Perfect Fit
🎉Newly launched! Toyota Tacoma 2024 5FT/6FT Custom Tailgate Mat, providing ultimate care for your beloved car.  💪🏻Perfect Fit With custom-fit design, it seamlessly matches your Toyota Tacoma 2024 - 2025. Whether it's a 5FT or 6FT model, it can be easily fitted, tailor-made for your vehicle.  🛠Easy Installation and Super Stable The installation process is effortless and convenient. The screws can perfectly match the original factory ones. No more installation troubles. Once installed, it's stable and safeguards your journey.  🌟High-Quality Material Adopting TPE raw material, it's not only environmentally friendly but also has excellent wear resistance and anti-slip performance. The scratch-resistant design keeps your car's tailgate looking brand new at all times.  If you want to get more details, please feel free to take a check here. Fit for Toyota Tacoma 2024 - 2025 5FT/6FT Custom Tailgate Mat's a 5FT or 6FT model, it can be easily fitted, tailor-made for your vehicle.  🛠Easy Installation and Super Stable The installation process is effortless and convenient. The screws can perfectly match the original factory ones. No more installation troubles. Once installed, it's stable and safeguards your journey.  🌟High-Quality Material Adopting TPE raw material, it's not only environmentally friendly but also has excellent wear resistance and anti-slip performance. The scratch-resistant design keeps your car's tailgate looking brand new at all times.  If you want to get more details, please feel free to take a check here. Fit for Toyota Tacoma 2024 - 2025 5FT/6FT Custom Tailgate Mat
