JustDSM
Justin
Ogden, UT
2024 Tacoma TRD Offroad
Overland Tailor Tuning (OTT) is proud to announce the official release of our highly anticipated ECU and TCU tuning solutions for the 2024+ Toyota Tacoma featuring the 2.4L (T24A-FTS) engine in both gas and hybrid variants. After more than 6 months of extensive development and in-house testing, OTT is excited to offer a precision-engineered, comprehensive tuning solution designed to optimize performance, enhance drivability, and improve reliability.
For those who are familiar with OTT from our work with the 3rd Gen Tacoma, you’ll find the same high level of commitment and precision in the new models. OTT’s tuning is designed with a focus on real-world reliability and performance, not just raw power—though the new platforms certainly deliver a punch! In some cases, they provide more than three times the gains compared to what was possible with the previous naturally aspirated platforms!
Key Features of OTT’s New Tuning Solutions:
  • Reworked Throttle Control Strategies: The new generation ECUs feature a completely new throttle control strategy compared to previous Tacoma generations. With this new strategy, we offer throttle sensitivity options of “Stock,” “Base,” and “Enhanced,” allowing drivers to tailor their vehicle’s throttle response to their preference, replacing the previous “Lite,” “Mild,” “Medium,” “Spicy,” and “Super Spicy” naming conventions.
  • Enhanced Throttle Response and Reduced Spool Time for Turbocharger: OTT’s tuning sharpens throttle response and reduces turbocharger spool time, allowing for more immediate low-end and midrange torque. This means the engine reaches usable boost pressure more quickly, improving drivability and acceleration, particularly during off-the-line starts and when accelerating from low RPMs. This results in a more responsive driving experience, with faster throttle reactions all with smooth delivery.
  • Rev Hang Reduction: For manual transmission owners, OTT’s tune reduces rev hang, allowing for quicker and more precise shifts. Currently undergoing testing.
  • Stage 0 Customization: OTT offers Stage 1 and Stage 0 tuning solutions, with TCU updates for each drive mode to enhance driving performance. Stage 0 is available on request for those requiring reduced output at lower boost levels.
  • SR Trim Calibration Option: OTT will offer the ability for SR trucks to receive “OEM Spec” calibration updates, bringing the base trim to the full output of the higher trim trucks. SR Trim vehicles are also supported in Stage 1 and Stage 0 configurations.
  • Fuel Requirements: OEM Spec through Stage 1 calibrations are designed for Regular to Premium fuel, with peak performance achieved on Premium (Recommended).
  • Exclusive Calibration Capabilities: One such ability is OTT's offering of a proprietary MAF calibration that ensures perfect integration with a retrofitted TRD Pro/Trail Hunter airbox, without triggering CEL codes. In addition, OTT is developing solutions such as Auto Start-Stop disable and other advanced vehicle customization options (to be announced at a later date).
Why OTT’s Tuning is Different from Piggyback Controllers:
Unlike piggyback controllers, which manipulate the signals between sensors and the ECU, OTT’s tuning works natively within the factory ECU. This allows for precise and real-time adjustments to parameters like throttle response, fuel delivery, ignition timing, and boost control, ensuring that the ECU receives accurate information for optimal decision-making.
Piggyback Controllers vs. OTT’s Native ECU Tuning:
  • Spoofing Sensor Signals: Piggyback controllers modify sensor inputs (e.g., MAF, boost pressure, and throttle position) before sending them to the ECU. This disrupts the ECU’s ability to make accurate, real-time adjustments.
  • Manipulated Outputs: These devices alter ECU outputs like fuel delivery, timing, and boost but lack dynamic, real-time adaptation, leading to inefficient engine management under varying driving conditions.
  • Risk to Vehicle Safety Features: Toyota’s ECUs have built-in safety mechanisms such as knock detection and overboost protection, and temperature-specific mapping which piggyback controllers can bypass, putting the engine at risk when factory signals are spoofed.
Why OTT’s Native ECU Tuning is Superior:
  • Native Calibration: OTT calibrations are directly integrated into the OEM ECU code, ensuring seamless performance optimization without the need for premium fuel exclusively. Unlike some piggyback controllers that restrict fuel choice. When the ECU remains in charge of decision-making, OTT can offer flexibility, allowing the vehicle to run on Regular or Premium fuel.
  • Reliability and Safety: By working natively within the factory ECU, OTT ensures your vehicle’s safety features, such as knock detection and overboost protection, and temperature-specific mapping remain fully operational.
  • OEM-Level Integration: OTT’s tuning is fully compatible with your vehicle’s factory systems, avoiding triggering error codes or safety warnings during service.
The Importance of Retaining Full Access to Diagnostics and ECU Programming:
OTT’s tuning does not lock down the ECU or restrict access to factory programming modes. Unlike some newer tuning solutions, which may lock diagnostics modes and restrict dealership access to the ECU, OTT ensures that dealerships can perform diagnostics and service without interference, preserving warranty coverage and avoiding issues during routine maintenance.
Why Choose OTT Over Other Tuning Solutions?
  • Native ECU Tuning for Reliability: OTT works directly within the OEM ECU, ensuring compatibility with Toyota’s factory safety features while maintaining system integrity.
  • No Service Concerns: OTT’s tuning does not lock down ECU access, meaning your vehicle can be serviced at the dealership without restricting access to diagnostic tools or having to remove piggyback devices.
  • Proven Performance: OTT’s tuning has been rigorously tested, providing proven horsepower and torque gains while ensuring your vehicle’s reliability and safety.
Pricing Information:
The 4th Gen Tacoma and 5th Gen 4Runner Calibration from OTT will initially be available only through an authorized OTT retailer. DIY options are coming soon, however. To ensure consistent support across the OTT network, we've developed custom hardware for our retailers, enabling direct ECU Read/Write processes for quick, efficient, and safe tuning.
  • MSRP through authorized retailers: $650 USD
  • DIY Kit Pricing: $950 USD (Includes VFTuner WiFlash Device & Software, Licensing Credits, Calibration suite, and shipping/handling)
    Note: DIY option currently requires a Windows-based PC. The software suite includes vehicle-specific protocols for reading/writing from the new generation ECU, as well as a comprehensive high-speed data logger.
    VFTuner "Legacy" users must upgrade to WiFlash for compatibility with the new ECU. An upgrade path will be available for prior WiFlash clients.
Revisions and Updates:
Revisions apply to your current calibration—whether it’s OEM Spec, Stage 0, or Stage 1. These updates are available at no additional cost (Retailers may charge a small service fee for time/labor related to revisions), ensuring that your tune stays optimized with the latest calibration advancements as software improvements become available.
OTT is also planning additional Staged packages to align with both current and upcoming bolt-on upgrades, keeping your vehicle’s performance evolving.
Additional Things to Know & Be Aware Of:
  • Multiple Calibrations for Each Trim: With the new generation ECUs, there are multiple calibrations available for each vehicle trim, unlike previous generations where a single calibration covered up to 2-3 model years. Due to this, not every vehicle will be immediately available at launch. OTT has worked hard to build the most extensive library of available calibrations to support as many vehicles as possible from the start so the impact should be relatively minimal.
  • Calibration Availability: We have a broad library of files ready, but new calibrations may occasionally surface. If your truck has a calibration that isn't yet available, it cannot be supported until we obtain a physical read of that ECU. If you help facilitate this by coming in for a read, OTT will offer a $50 incentive. OTT and VFTuner greatly appreciate your assistance!
  • New 2025 Models: With the release of the 2025 models, OTT is in the process of building a calibration library for these new ECU ID’s. It should be expected that 2025 model year vehicles will require us to read the files, and these files might not be immediately available until we’ve built the library.
  • CARB-EO Compliance: OTT is working to obtain CARB-EO for Stage 1 calibrations, ensuring full compliance for customers in California and other similar-regulated states. This effort will ensure that OTT’s tuning solutions remain fully street-legal in these areas, allowing performance enhancements without violating emissions regulations.
  • Revisions and Updates: Revisions apply to your current calibration—whether it’s OEM Spec, Stage 0, or Stage 1. These updates are available at no additional cost (Retailers may charge a small service fee for time/labor related to revisions), ensuring that your tune stays optimized with the latest calibration advancements as software improvements become available.
  • OTT is also planning additional Staged packages to align with both current and upcoming bolt-on upgrades, keeping your vehicle’s performance evolving.
Stage 1 Dyno Results:
i-Force (SR5-TRD Trims)
RED: OEM Calibration, Stock Vehicle, 91 Octane
BLUE: OTT Calibration, Stock Vehicle, 91 Octane
i-Force MAX (Hybrid TRD Trims, Inc. Pro/Trail Hunter)
JustDSM
JustDSM
Justin
Ogden, UT
How hard is it to go back to stock? If I'm DIY, can I also do that on my own?
No issues at all. You’ll have the ability to flash back to stock or to any other tune options we have, at your leisure.
Duce95
Big Deezy
2024 TRD Off-Road Premium
Any issues using a CAI from SXTH element with these tunes?
JustDSM
JustDSM
Justin
Ogden, UT
None at all. @HardCorTaco was one of our early testers who fitted their intake.
We collected data, and its MAF housing/design is within an acceptable range for use with our tune.
The only one we know to be a problem at the moment is the TRD Pro/Trail Hunter airbox which needs a special calibration for it (which we have available).
Duce95
Big Deezy
Great. I have an OR non hybrid.
LincolnSixAlpha
Phoenix
Have to say I like your write up. Generally speaking as an older person who once was always tuning his vehicles back in the day, shy away from this stuff much these days. But I like how you're going at length to protect the stock ECU, leaving it unlocked for factory access.
I will mention back in the day I owned a 2011 Mustang GT500, upgraded the Super Charger on it and the tuner, whom offered the complete package of SC, tuner, and custom tunes along with all needed hardware/accessories almost bricked my ride. Luckily he was able to recover it, so it all turned out well. Was a corrupted file.
With that said, you mention access to updates, can you install the updated ECU firmware over the existing, or do you have to back out the previously flashed firmware before installing the newer upgrade?
JustDSM
JustDSM
Justin
Ogden, UT
Hi Brian,
Thank you so much for the kind words! I appreciate your feedback.
As for your question about factory updates, If Toyota releases a factory calibration update, the dealer can service the vehicle and apply the update, as we don’t lock down the factory diagnostic functions.
Regarding applying the calibration over the updates, there's no need to revert to an older OS Strategy. Should an update be released, we can integrate it directly into the new OS and rework the new calibration to our specification, ensuring that the fixes Toyota has implemented are addressed. OTT always aims to ensure our calibrations incorporate the latest factory updates to keep your vehicle running smoothly. It's never a case of having to choose one or the other – our goal is to have your truck both tuned and fully up-to-date.
If this situation arises, you can visit one of our retailers within our network. No matter where you are, they’ll be able to provide you with the updated calibration, along with full support and coverage wherever your travels take you.
Zanez
Zane
Cali
I live in a very remote area and have no idea how to find authorized dealers to do an OTT on my 2024 TRD off-road. I will be traveling from California to Missouri in April. Can you tell me how to find an authorized dealer? I'll be going through Reno, salt lake City, Colorado springs and Omaha to name a few. Thanks in advance for your help
UT
https://overlandtailor.com/retailer-locations/
I just moved from the Ogden area and I know they have location in the SLC/Ogden area.
Zanez
Zane
Cali
Thanks!
