2.4 Rattle / Knock noise under load - does yours sound like this?
wire4money
Tim
Las Vegas
2024 Ice Cap SR5
I completely agree that these trucks should all have the giant underhood noise-reduction pad; well, maybe it would have been excusable to leave it off the SR model. In that rev range, this is the worst-sounding engine, including '80s diesel cars, that I can ever recall. And I'm an old guy. I'm considering ponying up the several HUNDRED dollars for the Toyota hood pad. I believe I read somewhere that the manual tranny trucks do not have the speaker-generated noise canceling function, so my truck may actually sound worse than the 99% that are automatics!
No need to pay hundreds
https://www.amazon.com/dp/B0DT43Z37...are=cm_sw_r_cso_cp_ud_dp_91M6JD7TEACC06E67W3F
Texas Bob
Bob
Thanks, I'll check it out! Has anyone already tried this Amazon/Nonsense-name mat to see if it reduces the noise much and if it appears to be high quality? It has zero reviews as of now. Also, it claims to provide both sound and heat insulation, which makes sense, but is there any risk of excess heat underhood caused by the mat? I suppose not since Toyota installs their own mat on certain models.
