2024 Limited power back window rattle
jkcerruti
Jaye
Ben Lomond, CA
2024 Toyota Tacoma Double Cab Limited
Does anyone else have an issue with the cable, or glass rattling on their trucks? I have tried to isolate it by putting some felt in the track near the cable on the passenger side, it seems to stop the rattle, but the window doesn't open with the felt blocking. I can also *barely* open the window and it seems to eliminate the noise, which makes me think the cable needs to be adjusted. Thoughts?
4g hybrid
Not for me.
My only rattle I believe is the trim frame around the HUD... Trying to figure out the most discreet way to address...
I agree with @Airborne - take it to your dealer and let them fix it. Mine does not rattle at all, so I think you are right that the cable needs adjusting.
jkcerruti
Jaye
Ben Lomond, CA
@Airborne, yes. I've had it 3 weeks, and 500 miles. The dealer I purchased from is an hour away, and the local dealer sucks. but I suppose you're right. I was just hoping it was a simple design issue that someone had figured out. Thank you everyone for your response.
Bravada
S.E. Texas
2024 Taco Limited i-Force Max
I have an unidentified noise in mine. I think it's the driver's door, but not 100% sure, could be driver's rear door. It's only starts above 45ish MPH. I dying to know if there is a specific potential cause as I too have a crappy dealer by me, the selling dealer is too far for a casual drop in.
