2024 Pro, hood alignment+ditch lights
ReddingonTRD
Sean
Orange County
2024 Tacoma TRD Pro
Hey friends! Quick question for ya: I followed the usual method to install Caliraised brackets and attached my Rigid ditch lights. I went with the “remove top bolt, attach, replace, remove the bottom bolt, and slide the bracket over and secure the 2nd bolt” approach. Despite my best efforts, the hood shifted slightly. Any additional tips to align the hood? It’s probably only off by a half mm, but it’s hard to rationalize any misalignment on a brand new truck :(. Apparently the bolts have a shoulder to auto align. Do you advise I remove the brackets, attach without, and start over?
Chance3
Woodland, CA
Sean, I am planning on the same light set up on my OR using the Caliraised lights and brackets. Any insights or suggestions on the install? I do have the factory installed aux switches. Can I assume your grill light bar is also Caliraised? Thanks, Mike
